| Home > Help Needed / General Tech Chat > my mg midget turbo | |||||||
7 Posts Member #: 1095 Junior Member |
14th Aug, 2006 at 10:02:38pm
im new to this site so hello everyone,
14th Aug, 2006 at 10:12:10pm
What have you done with the ignition system? If you have left it standard the chances are there is too much total advance which has lead to detonation and this has taken out the head gasket.
14th Aug, 2006 at 10:27:41pm
erm we dont realy no its probably the standerd ammount that a metro turbo puts out it wont be much also our boost gage is connected up to the pipe that goes from the dump valve to the manifold is this the correct place to put the boost gage pipe? yes the ignition system is standerd, can you recomend a ignition system that will help stop detonation? thanks for the help and ill be in contact with benross soon
14th Aug, 2006 at 10:31:19pm
Standard boost will be 4psi-ish.
14th Aug, 2006 at 10:41:58pm
ooh coinsidence, i was looking at this about half an hour ago http://www.turbomidget.connectfree.co.uk/nographics.htm On 26th Oct, 2004 TurboDave16v said:
