| Home > General Chat > Electronic Boost Control | |||||||
193 Posts Member #: 437 Advanced Member Sunny Blackpool |
15th Aug, 2006 at 10:58:46am
89' Metro Turbo
15th Aug, 2006 at 11:02:08am
You really dont need anything as fancy as an apexi item to do the job on our simple cars.
15th Aug, 2006 at 12:51:17pm
Still on a distributor setup, but sounds like a good method mini1071s.
89' Metro Turbo
15th Aug, 2006 at 02:37:44pm
Mapped ignition is definitely on the to-do list for the car, my thoughts were only that if the likes of Miniwilliams can achieve 200bhp using a distributor, then perhaps it could wait for the future.
89' Metro Turbo
17th Aug, 2006 at 02:08:00pm
imo boost controllers are the way forward and not a chav idea. they cut the boost pipe from the turbo to actuator and only allow pressure through when required. this stops the waste gate opening progressivly up to you set pressure.
82 Posts Member #: 42 Advanced Member Doncaster |
17th Aug, 2006 at 03:19:10pm
What Peter is suggesting is that a MBC (Manual Boost Controller) will do the same job of preventing the wastegate actuator "seeing" boost until a pre-set pressure is achieved.
Edited by GTM Turbo on 17th Aug, 2006. |
17th Aug, 2006 at 03:36:38pm
The emerald also can manage boost. it can alter boost depending on which gear you are in or via rpm.
17th Aug, 2006 at 03:52:12pm
There are lots of things I could think to spend £180 on that are superior IMO to this box of Japanese "Fast and Furious" trickery......
17th Aug, 2006 at 04:46:29pm
I tried unsuccesfully to run boost vs rpm with my DTa setup, and hence will be purchassing an Apexi unit for once the injection goes on. These are mappable against RPM aswell - which is what i want to achieve.
Edited by turbodave16v on 17th Aug, 2006. On 17th Nov, 2014 Tom Fenton said:
17th Aug, 2006 at 04:54:52pm
i agree that £180 could be spent on a lot of other things and that there are other ways of doing the same thing. but then again a distributor does the same as an ecu and people here have gone for the ecu (me included) and still dont have the same power as say mini williams.
17th Aug, 2006 at 07:20:55pm
have you seen the emerald setup dave?
17th Aug, 2006 at 07:30:17pm
DTA also has it boost/RPM Iain...
17th Aug, 2006 at 08:02:05pm
the apexi AVC-r is an awesome piece of kit. if you can figure a way to fit a speed sensor it can predict your gearign and then it can set you up with whatever boost you want in whatever gear you are in!.. the injector wire is only used to determine engine speed, this can be wired to an RPM signal source instead, for example, the negative side of your coil. turbo 16v k-series 11.9@118.9 :)
17th Aug, 2006 at 08:20:24pm
eboost is suppost to be better than apexi or greddy
AlexF |
17th Aug, 2006 at 08:24:52pm
On 17/08/2006 20:20:24 AlexF2003 said:
eboost is suppost to be better than apexi or greddy Alex I've hear exactly the opposite - that the Apexi AVC-R is the best one available
Guess it depends on which you've purchased now doesn't it... All I know is that behind the chav blue screen is a very reliable RPM target boost controller - and that it won't const the earth if purchased stateside... On 17th Nov, 2014 Tom Fenton said:
17th Aug, 2006 at 08:43:40pm
werid!
AlexF |
17th Aug, 2006 at 09:25:01pm
I have fitted and played with alot of AVC-r's and the various greddy efforts. love the AVCR, for ease of use and featureset. never installed or used an eboost before so know nowt about them.
18th Aug, 2006 at 03:31:16am
On 18/08/2006 01:39:10 mini1071s said:
I like the fact we can all disagree and no one gets out of prams :) oh yeah! That's definately something we all agree on :) On 17th Nov, 2014 Tom Fenton said:
