Home > A-Series EFI / Injection > injector differences
dev
Member #: 1158
Manchester
What the difference between MJY100460 and MJY100123?
In english please guys.
Dev
TurboDave said
"Fab's right of course.
Maybe you should take your styling ideas off the French instead! "
460 flows around 460cc per min (numbers is a coincidence) and 123 flows around 300cc/min (google it to be sure) and also has a slower response...
dev
Member #: 1158
Manchester
Will i be able to use these Dave or am i best trying to get 4 x 460's?
dev
Member #: 1158
Manchester
actually they are MJY100023's does this make a diff?
Will these work as well as 460's?
I knew what you meant Dev.
These don't flow as much as the 460's, and have a slower response. Put them back on the 'bay' - but give information on the flow characteristics first. If you PM Jimster he'll tell you what they are flowwise, as he's running the same ones in his 8-port motor......
Edited by turbodave16v on 15th Aug, 2006.
dev
Member #: 1158
Manchester
can i use 460's on 8 port?
yes - but you don't have an 8-port, or 460's... (confused)
dev
Member #: 1158
Manchester
I have two 460's just need two more!
just was thinking about what you said about 's being some of the best injectors.
i'll think on.
supercharged cooper
Member #: 1219
What are you trying to do with them???
Im using 2 460's with an Eaton blower very successfully right now
dev
Member #: 1158
Manchester
use 4 460's on an eaton blower. with either 7/8 port head.
supercharged cooper
Member #: 1219
Your a brave man, sequential injection.......................how long you got LOL
Dev
I've seen Rover injectors with red rings described as from the T16 engine.
Do we know which of the above have the red rings?
I tried to get some more MPI injectors at MITP today. I found two MPI inlet manifolds, throttle bodies etc. One guy wanted £85 and the other £100*frown*
So i've resorted to finding alternatives.
The 460's have blue rings. I know that for a fact.
supercharged cooper
Member #: 1219
2.0 litre Rovers used the same injectors as the MPi, need to be late 90s vintage though
=> 92 (M series) MYJ10011
92=>96 (T nasp) MJY10029
92=>96(T Turbo) MJY10023
600
=>AM246796 (T Turbo) MJY10023
BM246797=> (T Turbo wasted spark?) MJY100460
800
91=>AM152056 (T nasp) MJY10011
AM152057=>230966 (T nasp) MJY10029
91=>230966 (T turbo) MJY10023
96(230967)=>(T Turbo + nasp) MJY100460
MJY100460 also fits
MPI Mini
RT420 T nasp
123 have red ring
Jimster/Dave,
Thanks.
As I'm only looking for around 120 hp from my 998, I think four of the 123s will be big enough, particularly if I raise the fuel pressure a bit.
I haven't tested the 123's - but I'd assume that they are an older generation injector that won't be as fast response as we need for injecting a 5-port A-series...
supercharged cooper
Member #: 1219
Axel, 120HP from a 998.................really?? I was going to supercharge and inject (using 2 460's) a 998 but was reckoning on a 100 at most.
What mods are you making to the bottom end?? Just a centre main cap or anything else special?!?!?!?
Others on this site have achieved 140 hp from a turbo 998.
I'm planning on a relatively standard bottom end with the addition of a centre main strap at most.
The thing is, you do not need to run high revs to achieve this sort of power with a turbo. Being an old man, I'll probably never go over 6000rpm. The stresses are more rev related than power related.
supercharged cooper
Member #: 1219
140 from a 998, thats just awesome!!!!
Thats it, Im gonna try and get over 100HP now with a supercharger on a 998. Absolutely mental! Im guessing that they just rev nice n freely though rather than drive like pigs
Read the section on 998s. There are a lot of us doing this.
You should easily get 100hp from 15psi boost, 120hp with an intercooler. I think you will need to cam it for more.
Having recently driven my lads 998, it does rev freely and is smoother than the wifes 1275.
supercharged cooper
Member #: 1219
Well it just so happens that I have a brand spanking new MG cam in the shed, cast off from one of my friends but I havent found a use as yet............could have just changed though!
dev
Member #: 1158
Manchester
Axel do you have your 4 123's yet?
if not i have 4 with a fuel rail and sockets.
they are going on the 'bay next week so let me know.
yours for 9.99 of your english pounds.
i'll take these if they're right for the old K1100 head *smiley* which it sounds like they are
obviously axel has first refusal
