Home > Help Needed / General Tech Chat > Rolling Road Checklist
Right, i've finally got my Mini booked in at Peter Baldwins rolling road, should only take me 6 hours or so to get there from the lakes lol, oh well ....
Anyway i've made a list of things to do to the car before it goes, can anybody think of anything else important i've missed ?
Besides video camera, money, mobile ...
Clean air filter, check dashpot oil, tyre pressures, set valve clearances, fit new plugs, leads, dizzy cap, rotor arm and oil and filter change ...
Anything else ?
Phil. *smiley*
Take at least ONE spare plug with you, aswell as EVERY tool you own! LOL!
Next - if you're plannign on running big boost, chances are you'll find the limit of the single grey - especially on the rollers - so be prepared to either not run all the boost you planned, OR think ahead and swap in a stronger clutch just for the day maybe?
If I were you - I'd plot a journey, and see if you can stop by a fellow TM's house - beers and a roof over your head is better than doing there and back in a single day...
Phil, bed here for you old chap if required?
Also usually worth setting tyre pressures higher than normal on the rollers.
phil a spare bladder!
for all the tea your gona drink at peters .....lol
Dangerous
Member #: 417
Plenty of fuel
either a notebook or a video or cassette recorder ,that way you can write down or record what happens,cos its very easy to be thinking bout it later on that week and get all tangled up in what you thought happened or where you thought the timing was etc
good luck phil hope its a grreat success!
T3Tone
Member #: 252
Sunny suffolk
If you have adjustable suspension, take the tools to enable the front to be adjusted in case your downpipe fouls the rollers.
-MINI CLUBMAN 1380 TURBO-
You want the tank as empty as possible makes it lighter, should go better. LOl *wink*
Also add some Maxpower stickers, I over heard someone called Chavalion (Chav for short) in Halfords car park, saying they add AT LEAST 10BHP!!
On a serious note, It sounds like you've got things covered.
Edited by matty on 22nd Aug, 2006.
fuel filter? your on a dizzy arn't you?? I'd also be tempted to take a spare just in case.
you've forgotten your sister in that list
then you can pop in via mine and ill look after her for the day
and take some oil with you too, just incase
Dangerous
Member #: 417
Make sure the sump plug is done up,don't wanna look a twat :$
ha ha ha!
http://www.turbominis.co.uk/iain/up/jf_rr1.jpg
Edited by turbodave16v on 22nd Aug, 2006.
Thanks for all the replies chaps, most useful. *smiley*
Thanks a lot Tom that's really appreciated. Unfortunatley i haven't got the next day off work, so i've got to do it all in one day. Thanks again anyway mate. :cool:
Well if you want to set off the night before and stop here you are more than welcome, up to you.
nic i dont think youll get on well enough with phils sister to need the oil..still, i like an optomistic outlook.
turbochargedstu
Member #: 908
gateshead
some cringe tablets. you will need these when you watch someone else scream the tits of your car!!!!
looks like everything has been covered. good luck!!!!
balls to the blower!!!
JT
Member #: 637
Hertfordshire
phil have you got megajolt or a dizzy?
let me know what peter baldwin is like with setting it all up as hes not that far from me (about 45minuets away)lol
i supose you could stop off hear if you wanted mate.
cheers
josh
My build thread..
