| Home > Help Needed / General Tech Chat > Engine build oil! | |||||||
22nd Aug, 2006 at 04:59:58pm
Went to local motor factors and asked the guy what would be a good oil to build/run in the engine on.
22nd Aug, 2006 at 05:17:32pm
Get the cheapest oil you can find, then change it often. Happy Shopper Multigrade or anything like that is fine.
Edited by Tom Fenton on 22nd Aug, 2006.
22nd Aug, 2006 at 06:02:06pm
Haha cool! So what happens to this paste when it mixes with oil does it dissapear or what? Do i just use it for the main and big end bearings and use a bit of oil on gudgeon pins and rings etc? |
22nd Aug, 2006 at 09:54:49pm
another old, like me......... but excellent product i use is........ STP OR WYNNS oil addative to build the engine
Edited by BENROSS on 22nd Aug, 2006.
23rd Aug, 2006 at 10:49:02am
As it gets hot it mixes and runs away. Use a smear on the bearing shells BUT ONLY ON THE CRANKSHAFT SIDE, THE REAR OF THE SHELL MUST MUST MUST BE DRY OR ELSE THE ENGINE WILL LOCK UP.
23rd Aug, 2006 at 01:40:20pm
Because if it was greased it would become un seated, move and lock the crank right? |
23rd Aug, 2006 at 01:46:27pm
I am sure Tom is meaning that if you lube the underside of the bearing it will in fact possibly make it seem thicker and therefore be tighter than it should be on the crank once torqued up.
23rd Aug, 2006 at 06:40:18pm
asda value is £2.89 at the moment in 5 liters of 20-50 Crystal Sound Audio said:
