Home > General Chat > Thickness of spacer on factory turbo carb/manifold...
Am i right in recalling that this is actually something like a 1/4" spacer - whereas the MG metro had a 1/2" spacer?
Anyone confirm?
Dangerous
Member #: 417
Yes and its also made of some hard materiel where as the N/a one is rubbery
dan
Member #: 93
yep i noticed that too,
do you think its related to the inlet on the turbo being a touch longer, or just trying to reduce the amount the plenum rides back into the bulkhead
I know the spacer is there to allow the throttle lever to clear the inlet manifold, the manifold also has a small machined rebate for this purpose too.
Remember in the metro dan, bulkhead clearance wasn't an issue, I have often wondered if they did it to limit heat soak from the inlet to the carb.
