| Home > Technical Chat > VNT turbo's | |||||||
26th Aug, 2006 at 09:46:53pm
I just came across this, theres some nice internal VNT shots.
27th Aug, 2006 at 09:45:33am
vnt turbos won't cope with very high temps and also with fuell deposit on the vanes: yes but,
27th Aug, 2006 at 12:25:17pm
Thats pretty much what I was thinking Fab,
29th Aug, 2006 at 03:54:31am
diesel engines are already blown to 15 or more boost, the dodge's were ok at low boost, I think you'll make more power with less boost on a vnt turbine as it will not restrict exhaust flow (on a well made with 15psi ..180+ bhp.), but with a cross flow head it will be sufficient to grenade traini's, drops and dif........I would be more worring about gears than the turbo :), don't choose a turbo that is to short for that kind of power you need a large turbine whell (the tdi 110 is too small, I would go for a vnt 2.5, 2.8 , 3.0 engine " fiat jtd 2.4" """could""" be good |
29th Aug, 2006 at 06:38:47pm
Thanks fab, interesting stuff
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
3rd Sep, 2006 at 12:33:03pm
I cant see how an engine boosted to same pressure will make a significant amount more Hp when using a VNT. At the end of the day the turbo is extracting energy it requires from the exhaust gasses. The amount of extracted energy will be similar on both turbos as the work it has to do is the same, i.e. supply 10lbs of boost. The amount of energy the turbo extracts from the exhaust gasses is propotional to the pressure drop and flow over the the turbine and this would be proportional to the back pressure on the engine. I can possibly see it being better when running off power around time. The VNT just allows the turbo to be more flexible with a wider performance envelope for any particular turbine.
Edited by Mirage on 3rd Sep, 2006. |
3rd Sep, 2006 at 12:52:40pm
I was thinking that as the VNT would be operating at a higher efficency (The AR varies to keep the exhaust closer to its most efficient point?) so less heat would be generated and transfered to the intake, also there would be less back pressure due to being able to run a higher exhaust AR without loss of bottom end. On 28th Aug, 2011 Kean said:
3rd Sep, 2006 at 01:05:29pm
nicely put mini13
Edited by robert on 3rd Sep, 2006. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3rd Sep, 2006 at 02:00:37pm
The VNT improves low down boost by making the nozzle smaller at lower revs. This ups the velocity of the exhaust gas hitting the turbine and spins it faster.
3rd Sep, 2006 at 03:00:26pm
thanks robert,
3rd Sep, 2006 at 03:42:46pm
I'm not disagreeing that overall the VNT would give a certain amount extra power at most revs but it may not give you a higher maximum power. If you optimised a standard style turbo for a certain power output lets say 150bhp at a given engine speed and a vnt made for the same. I don’t think you would see much of a difference when the engine was operating at this power/rpm range. Both setups with similar back pressure etc.
3rd Sep, 2006 at 04:15:26pm
Your right I think any benifit from back pressure related gains may be small but should be there,
4th Sep, 2006 at 05:50:57pm
in fact that's not so....simple,and my apologies for this at anyone would be touched.
