| Home > How To > Fitting a bleed valve | |||||||
17th Jun, 2003 at 06:48:17am
![]() 323 Posts Member #: 41 Senior Member |
7th Aug, 2003 at 06:02:16pm
i want to run my turbo while its being run in on standard boost with no bleed valve or boost siwtch, (the soleniod that lowers the boost in lower revs) so to do this do i just need to block up the brass t peice that is screwed into the housing that comes from the actuator or do i need to connect the end of the t peice to somewhere else?!
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
244 Posts Member #: 34 Senior Member |
1st Oct, 2003 at 12:14:29pm
Bleed valves are adjustable to the point that they block the pipe and don't bleed air, so you have no worrys during running in, just set the valve fully closed. |
![]() 52 Posts Member #: 75 Advanced Member |
25th Mar, 2004 at 11:51:46am
What kind of bleed valve should I use? Is these any good? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...MEBWA%3AIT&rd=1
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
25th Mar, 2004 at 02:34:29pm
the item on ebay is not a bleed valve, it is a pressure relief valve which is better. it allows the boost to reach a preset level, say 10p.s.i, then it will operate the watsegate actuator. A bleed valve meters off air from the actuator but the wastegate can still open slightly which means you will be losing boost in midrange. |
26th Mar, 2004 at 07:05:21am
the "grainger" valves are the best boost controller you can find,
26th Mar, 2004 at 07:12:51am
easy easy boost controller:
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
18th Jan, 2005 at 04:13:33pm
so to clear up, a manual boot control valve (MBC) goes INLINE. but the bleed valve uses a T peice in the same line?
339 Posts Member #: 399 Senior Member Austria |
19th Jan, 2005 at 10:32:33am
Not to the question of pot_dan, but adequate to this topic...
Edited by akirch on 19th Jan, 2005. |
19th Jan, 2005 at 02:04:28pm
Clever little idea ! |
397 Posts Member #: 694 Senior Member Shropshire |
18th Apr, 2016 at 12:39:32pm
Can anyone resurrect this guide or update the pictures? |
