| Home > Help Needed / General Tech Chat > 1275 Metro NA ---> TUrbo 100HP | |||||||
113 Posts Member #: 1230 Advanced Member |
28th Aug, 2006 at 08:44:45pm
i have an NA 1275 engine from a metro, i'm going to turboing it , but i only want 90, 100 HP, so the only thing i need to change is the carb? anything else? thanks Edited by beestje007 on 28th Aug, 2006. |
28th Aug, 2006 at 08:46:02pm
oww and where can i find a turbo carb, that wil be a the HIF44
30 Posts Member #: 1213 Member Cyprus |
28th Aug, 2006 at 11:42:17pm
pressure fuel regulator, oil cooler, manifolds, oil suply to the turbo, oil return pipe, air intake pipe, downpipe, high capacity oil pump, plenum, PISTONS etc etc. Personlly i dont think is a good idea to only add a turbo!! Edited by ClubmanTurbo on 28th Aug, 2006. |
28th Aug, 2006 at 11:43:18pm
pressure fuel regulator, oil cooler, manifolds, oil suply to the turbo, oil return pipe, air intake pipe, downpipe, high capacity oil pump, plenum, PISTONS etc etc. Personlly i dont thing is a good idea to only add a turbo!! |
29th Aug, 2006 at 08:16:56am
yeh thats what i thought, because some people say that its enough to add the in and out manifolds and oil cooler , oil lines and turbo and turbo carb.. |
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
29th Aug, 2006 at 01:29:53pm
I think you'll get away without an oil cooler. I know one guy on here who had a standard 1275 bottom end and only run low boost, i don't think he had any problems.
29th Aug, 2006 at 01:47:59pm
You'll get away without an oil cooler easily. Also, standard pistons if in good shape are also up to the job. The only difference being the N/A piston to be of the "slipper" type
Site Admin 6302 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
29th Aug, 2006 at 01:54:32pm
142bhp and no air-to-oil oil cooler here. |
29th Aug, 2006 at 05:01:01pm
that's about the only thing my car has that yours doesn't!! lol!
