Home > A-Series EFI / Injection > Cam sensor idea???
Found this http://www.dormanproducts.com/documents4rb...nchronizers.pdf
Looks like it fits where the dizzy would be. Doesnt look like they do one for the A series, but maybe some one can make similar, cant be that hard. Infact would be quite easy to fit a cam sensor inside an SPi dizzy, cos theres nowt in there anyway.
I had a cam phase sensor made from a dizzy when i was on Weber Alpha. All pretty simple stuff TBH.
I don't know if it's any help but I came across a zetec turbo on the web which got round the cam sensor issue by inserting to large grub screws into the cam.
http://www.rsrich.force9.co.uk/zetec-turbo/management.htm
It's not pretty but it works, apparently.
supercharged cooper
Member #: 1219
Why dont you just modify a sensor to fit inside the dizzy head and reads the rotor arm???
Failing that if you need to keep the dizzy operational, put a sensor in the rotating shaft (prob underneath and behind the mechanism) and machine a slot in it
Isnt the electronic ignition dizzy just a magnetic trigger anyway ? with 4 teeth on it ?
If you need 1 tooth, cut the other 3 off.
