Home > Wanted > Front wiring loom (just engine bay bits)
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Hi, after the last loom fried (the white wire melted everywhere!) ive had to replace it, ive done the interior dashboard etc bits, but when unwinding the replacement loom it looks like the engine bay part it shot to bits. I have lots of cut up ones, but if anyone has one (from bulkhead forwards) ill buy it! I can solder the wires and plug everything in then. The interor one i wanted mark one you see because of the clocks too and the adapter i made for my dashboard.
I think a metro one will also do, so if somone has broke one i could always use that and work out the wires. Anythings better than bodging the current one back to working order! Might use the bodged one to lengthen the original one to stealth it behind the inner wing or something.
james
jamesfawcett
Member #: 218
Im really desperate for one, anyone know any 2nd hand mini garages im likely to find one?
