Home > General Chat > Micro Dynamics Turbo Ignition Managment System
Does anyone have some instructions for the Micro Dynamics Turbo Ignition Managment System?? If so could you email me them.
Instructions-
Step 1 - Remove from car
Step 2 - Place in bin
Step 3 - Fit MegaJolt or similar.
The Microdynamics thing is little better than junk I am afraid........
I bought a boat load of spares and it came with it, what is the purpose of it and why are MegaJolts Better??
It serves to retard the timing with increasing RPM.
However this is really not ideal as what you want to achieve is to retard the timing with increasing boost pressure. The MegaJolt CAN do this and is ideal for our application.
Hokay.........................................................Anyone want to buy an EMS5??????? HEHE
Ok, i have just been readed Nics write up fitting the MegaJolt Setup and i must admit it does look alot better.
However on the Megajolt site should i be buying the Megajolt Lite Jr.- Complete unit ??
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5741
It is up to you how you go about getting the MegaJolt ECU.
You can either order it direct from Brent Picasso (the guy behind it) in the USA, or ALEX_F on here sells them. Or if you are feeling keen with the soldering iron you can order the components and build your own.
Does it make a difference in the driving experience compared to the standard Dizzy?
Regards
yes - and it also doesn't cry when you take the mini out in the rain (BIG advantage!!!!)
i cry when i take my car out in the rain
andeh
Member #: 97
Near Daventry, midlands
This reason more than justifies the cost/fitting expense, everything else (performance, adaptability, reliability, control, limiters, etc, etc) are all a bonus. Anyone who’s driven a mini for a prolonged period during winter will know this very, very well!
Nick
Member #: 154
Midlands
yup, hence why i've stuck my jolt onto my bog standard daily driver 998 while the turbo's being rebuilt.
Coedy
Member #: 1031
Swansea (S.Wales)
bud, any good? did think about getting it before i get the turbo running then once the insurance comes down a bit i can upload a turbo map?
Project - 998 turbo
