| Home > Help Needed / General Tech Chat > Roll Pin | |||||||
1st Sep, 2006 at 04:58:32pm
I've just got the engine running again after fitting the new clutch seal.
1st Sep, 2006 at 05:01:22pm
New pins are always tight, yes they should close up a bit as you drive them in. 1/4" does sound a little large though, but unfortunately I do not have one here to measure for you.
1st Sep, 2006 at 05:20:42pm
The other annoying thing is that I bought a roll pin from a stall at MITP the other week. That one turned out to be too small - 5mm OD.
1st Sep, 2006 at 05:41:11pm
1/4" feels too large to me aswell...
1st Sep, 2006 at 06:11:11pm
the hole is 5.1mm when i last measured it, |
1st Sep, 2006 at 06:14:26pm
I hate those little buggers,
1st Sep, 2006 at 06:19:32pm
Mini13,
1st Sep, 2006 at 06:27:08pm
I think its just an M5 caphead with 2 nuts locked together,
1st Sep, 2006 at 08:53:11pm
why not drill it all out to 1/4, or what ever size roll pin is easily available? |
2nd Sep, 2006 at 01:19:30pm
Which way do the roll pins come out?
2nd Sep, 2006 at 01:53:31pm
Put the gearbox in reverse and wollop it from the drivers side with a lump hammer and a decent punch. I use a 5mm drill flattened at the sharp end.
2nd Sep, 2006 at 03:15:07pm
Reverse is the way to get them out, I have a proper roll pin punch with a "tit" on the end that locates in the hollow centre of the roll pin, makes it loads easier as the punch now cannot slip from the right place, so all you have to do is wallop it.
2nd Sep, 2006 at 05:04:16pm
I and a lot of other peaple use a small jewellers screwdriver so the blade of it fits in the hole in the pin,then tap it out
2nd Sep, 2006 at 06:17:54pm
4" nail for me!! |
2nd Sep, 2006 at 07:34:04pm
I have a fairly old pin that is not overly tight and secure it with lock wire. Cut the wire and drifts in and out nicely. On 5th Sep, 2011 Vegard said:
2nd Sep, 2006 at 09:29:48pm
[quote=Tom Fenton,02/09/2006 15:15:07]
never had one not come out.
