| Home > Help Needed / General Tech Chat > Ign timing to suit cam(up dated) ? | |||||||
3rd Sep, 2006 at 09:49:48am
Had the metro tuned thursday timing set at 8 btdc 1500rpm vac pipe off(std metro turbo setting),went out and very little power below 3000rpm,struggling to pull away but fine when moving
Edited by Dangerous on 3rd Sep, 2006.
3rd Sep, 2006 at 12:16:49pm
as long as it does not det bri you will be fine buddy
Edited by BENROSS on 3rd Sep, 2006.
3rd Sep, 2006 at 12:24:55pm
cr approx 9:1
3rd Sep, 2006 at 06:22:35pm
I have to run mine at at least 15deg at 1,500 rpm other wise it's flat as hell and it's really hard to pull away.
3rd Sep, 2006 at 08:25:03pm
Phil, junk the dizzy and move to the megajolt buddy, this is the way forward.
3rd Sep, 2006 at 08:30:06pm
or go for fixed advance like mine , mine is fixed at 27 deg but retards to 24 deg when over 3500 it does this on its own ( its a bit worn i think)
3rd Sep, 2006 at 09:45:03pm
On 03/09/2006 18:22:35 Turbo Phil said:
I have to run mine at at least 15deg at 1,500 rpm other wise it's flat as hell and it's really hard to pull away. Hey that sounds like mine What cam is that running ?
3rd Sep, 2006 at 11:14:40pm
why would you want fixed timing?
AlexF |
4th Sep, 2006 at 08:33:06am
I have to run mine at at least 15deg at 1,500 rpm other wise it's flat as hell and it's really hard to pull away. Hey that sounds like mine What cam is that running ? Phase 3 mate.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
4th Sep, 2006 at 10:39:43am
the problem you've got bri is that the std turbo cam is the same as a std NA cam and this requires a very differnt advance curve than the 276 (which was my na cam aswell). you dont need any more total advance, maybe even a bit less depending on boost levels, but you need a lot more low down to compensate for the naff cylinder filling capabilities of the 276 at low revs. This is only compounded by having a low c/r.
4th Sep, 2006 at 02:55:16pm
Ive just started collecting and ordering bits for a mj,think that will fix it.
