| Home > Help Needed / General Tech Chat > Clutch Oil Seal - SORTED ??? | |||||||
3rd Sep, 2006 at 04:58:37pm
The f@cking clutch oil seal has gone again.
Edited by Paul S on 24th Sep, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
3rd Sep, 2006 at 05:53:27pm
Are you certain its the seal and not a cracked case?
I seriously doubt it! |
3rd Sep, 2006 at 06:02:53pm
Paul,
Edited by Paul S on 3rd Sep, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
3rd Sep, 2006 at 06:04:35pm
You haven't got excess endfloat/wear on the primary gear have you ?
3rd Sep, 2006 at 06:06:20pm
I,ve got the minimum end float on the primary gear 0.0035" and it is in reasonable condition.
3rd Sep, 2006 at 08:53:48pm
Right, the plan is to get the transfer case off whilst the engine is in the car.
3rd Sep, 2006 at 09:53:20pm
I have never tried to be honest, compared with the struggle of trying it, I'd rather pull the engine personally.
3rd Sep, 2006 at 11:41:51pm
On 03/09/2006 18:06:20 Axel said:
It is grooved where the seal runs, but aren't they all? No
4th Sep, 2006 at 12:06:10am
On 03/09/2006 20:53:48 Axel said:
Right, the plan is to get the transfer case off whilst the engine is in the car. I'll check the case for cracks etc. It may be the araldited bearing removal holes leaking when it gets hot. Then fit a new seal with another primary gear. Can anyone confirm if it is possible to remove the transfer case with the engine in the car? ive done this and it can be a right pain in the ass i had to practically take the engine out anyway, floating it on a jack. if i were doing it again id just take the whole lot out. thats on my 74 clubby. i did it once on me 93 car and it were easier, i think because the engine sits a bit further back in me clubby or the subframes slightly different. no longer a series, but still 1.3 turbo.
4th Sep, 2006 at 12:51:45pm
simple job
4th Sep, 2006 at 12:54:22pm
think he wants to change the casing as he isnt convinced its right |
4th Sep, 2006 at 12:54:26pm
forgot to add. it cant realy be the casing, but only the primary gear or seal |
4th Sep, 2006 at 01:13:01pm
It could be the casing for two reasons:
4th Sep, 2006 at 02:33:44pm
Surely this comment:
It is grooved where the seal runs, but aren't they all? Tells you that the problem was the primary gear, NOT the casing???? Heed the advice of the shed I reckon... Why make things hard for yourself? On 17th Nov, 2014 Tom Fenton said:
4th Sep, 2006 at 04:21:36pm
You can definately take it out, its a bit of a squeeze. I haven't got a brake servo though if you have it could make all the difference.
4th Sep, 2006 at 05:18:24pm
Dave,
4th Sep, 2006 at 06:49:14pm
coulkd be the hole you drilled ( should have left it in the oven longer) but i recon go with the shed and also make sure the oil reiev holes aint blocked in the primary gear as the will make matters worse. always looking for them bigger bunches of bannanas |
5th Sep, 2006 at 12:00:31am
On 04/09/2006 14:33:44 TurboDave said:
Surely this comment: On 03/09/2006 18:06:20 Axel said:
It is grooved where the seal runs, but aren't they all? Tells you that the problem was the primary gear, NOT the casing???? Heed the advice of the shed I reckon... Why make things hard for yourself? The primary in my 1400 is ever so slightly grooved, was considering ditching it but couldnt find another in time so bit the bullit and used it. 1200 miles in and reved to 6k at avon 200miles in (LOL) and it's not leaked from the primary gear seal. Thats with the Black seal from Minispares and fitted with the seal tool. so not always a problem. Still, i'll admit that i would have replaced it if there was one going spare. As for drilling holes in the transfer case?????????? I took my case to the local transmission center, they charged me a fiver to remove the two bearings and gave me a gearbox gasket set as well when i asked. Top chaps they were
Edited by Sprocket on 5th Sep, 2006. On 26th Oct, 2004 TurboDave16v said:
5th Sep, 2006 at 12:11:34am
I roll lapped my seal face to remove the wear mark and give it a 2 micro inch cla finish
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
5th Sep, 2006 at 09:00:40am
Last time i had a oily clutch it was due to excessive clearance on the primary gear, normal engines need to run about 3thou clearance on the crank, fast roaders 4thou and anything fast with a minimal clutch upto 6thou. Passed this 6thou point the primary gear will pass oil excessively. If you dont have the kit to measure the gap gimme a call and i'll pop over with the measuring equipment. I've seen the future and tbh its Pie
5th Sep, 2006 at 11:26:46am
Guys,
8th Sep, 2006 at 05:31:05pm
UPDATE
Edited by Paul S on 8th Sep, 2006. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
8th Sep, 2006 at 07:20:43pm
I know for a fact that Araldite softens with heat, I would change that casing too mate.
8th Sep, 2006 at 07:27:55pm
You can get a floating bush to go in there,I'm using one.Just put it in no honing etc
8th Sep, 2006 at 08:08:52pm
I thought you have to measure the clearance with the gear and bushes in place with a feeler gauge?
