Home > Help Needed / General Tech Chat > Bottom End requirments for high reving engines
Anton
Member #: 764
Staffordshire
starting to get a bit edgey with my new engine, and thinking I should have uprated some of the components in my bottom end to enable to to start reving it into much higher rpm's. Now we all know rev are what kills engines but what kinda things should I be looing at changing to allow say a 7.5k or 8k rev limit. atm its pretty standard (all fresh and new tho).
Current ideas are:
arp rob bolts (a must)
a fully worked crank, cross drilled etc
maybe a 4 bolt cms
any ideas?
johnK
Member #: 690
Norfolk
Hi Anton - as an example and for information only, I ran my 1380 5 port to 8.2k, bottom end was wedged cross drilled nitrided crank with a steel main cap, innocenti rods - though A+ seem trouble free as well, ARP bolts, u/light flywheel/backplate - and the prpoer Vanderval bearings. The crank and rods live on and are now in K motor and running to 8.7K - with a steel 4 bolt main.
If Carling made Mini engines
andeh
Member #: 97
Near Daventry, midlands
balance is key to longer life high revving engines, this is why i spent £150 getting a full rotating balance on my engine which will also be revving upto (and probably over) 8,000rpm
Who did your 4-bolt mains Pete, would be interested to see other companies take on the subject....
I change up at 3000 rpm. LOL.
Sometimes get to 4000rpm in top.
I dont understand?
This sounds very interesting, I'd love to see some pics of this 4 bolt main that ties in the sides of the block etc, that was a thought I had some time ago after messing around with Pug engines as these have cross bolted main caps.
On 04/09/2006 19:49:43 mini1071s said:
I'll do that after I have the engine running and I know it works.
Everyone on here shares their trials, successes and failures! It sounds damn impressive Pete, show off for once! If it doesn't work then at least you had the guts to try!
http://i24.photobucket.com/albums/c2/carl1964/000_0109.jpg
http://i24.photobucket.com/albums/c2/carl1964/000_0171.jpg
some of these
http://i24.photobucket.com/albums/c2/carl1964/000_0104.jpg
Edited by fastcarl on 4th Sep, 2006.
Nick
Member #: 154
Midlands
You've got to the point now where it gets really expensive to get any quicker ant. told you you should have turbo'd it *wink* hehe.
Tis a lovely car to drive though, glad you actually stuck a 300deg cam in there rather than listening to all the doubters on other forums. oh no any more than a 286 and it wont idle, it wont do anything unless you sidestep the clutch at 3500rpm etc etc etc.
