Home > Help Needed / General Tech Chat > Fuel line Length?
gtbuzzmini
Member #: 1195
Fort Worth, TX USA
I am prepping for my metro turbo swap next month, and was going to be getting the new fuel lines (both feed and return). The car is up at my father's place so I can't measure the length of the existing line. Anyone know how much line I will need? Thanks for the help
Matt
It depends on a few things really, like tank return position, position of regulator, where you run your pipes etc..
I seem to remember I bought 4 metres for the feed and 4 metres for the return.
I had some left over, but in the words of Les Cant (a Geordie of much wisdom) "I'd rather be looking at it than looking for it"
Wil
gtbuzzmini
Member #: 1195
Fort Worth, TX USA
Thanks. I was just looking for a round about figure, and like you said, extra is not always bad.
Matt
Richie
Member #: 628
i think the diameter of the pipe is important too, 8mm feed and 10mm return (if i recall correct) just in case you didnt know.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
Jackman
Member #: 984
Westhoughton, Bolton
Any reason why it has to be a 10mm return? I thought they could be the same.
Manchester Minis
Ahh, the eternal debate about fule line sizes. I run 8mm and 8mm and it's fine. before, I ran 8mm feed and 6mm return and that worked fine too.
I think as long as the return is free enough to allow you to get the fuel pressure down to 3.5 to 5psi at tickover then that's fine. The regulator should componsate after that.
gtbuzzmini
Member #: 1195
Fort Worth, TX USA
My plan was to go 8mm both directions as I have read enough people doing this with no problem. Thanks
No matter what fuel pipe you run - if you can get down to 1.5/2.0psi (between regulator and carb) with the regulator adjuster screwed right out, you will be ok.
If you can't go this low then you either need a larger return, or a restrictor at the entry to the regulator. Simple.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=1456
Jackman
Member #: 984
Thanks alot :)
Manchester Minis
