Home > Help Needed / General Tech Chat > HIFF44 turbo carb
beestje007
Member #: 1230
Hello, does a HIFF44 turbo carb also work without a turbo? And the oil inlet of the T2 turbo is it the big or the smal hole? Where do u have to connect the oil in and outlet ? because not all 1275 engines have an extra oil in or outlet? thanks
Carb will work normally aspirated, yes. It does before any boost is made, of course.
Oil inlet is small and outlet is big on T2.
Generally oil to the turbo is taken from the oil pressure take-off on the front of the block and returned through the fuel pump hole on the rear of the block (or through a return adaptor tigged to the gear box.)
