| Home > General Chat > Mapping on a laptop | |||||||
193 Posts Member #: 437 Advanced Member Sunny Blackpool |
8th Sep, 2006 at 03:48:27pm
89' Metro Turbo
568 Posts Member #: 102 Post Whore Pennsylvania USA |
8th Sep, 2006 at 04:11:09pm
Anything will do from the last 5-6 years. Make sure it has a serial port. The USB adapters are a pain in the arse. |
8th Sep, 2006 at 04:27:36pm
Daft question, but do I actually need a laptop if I am taking it to a rolling road for mapping?
89' Metro Turbo
8th Sep, 2006 at 05:22:38pm
Yes you will need a laptop, it is unlikely the RR operator will have a laptop with the correst version of software (unless you are using Emerald and going to Dave Walkers RR, or something similar)
http://www.twin-turbo.co.uk
8th Sep, 2006 at 07:03:20pm
Cheers for the feedback, I know what I'm looking for now.
89' Metro Turbo
9th Sep, 2006 at 09:39:39am
On 08/09/2006 17:22:38 Ben H said:
Yes you will need a laptop, it is unlikely the RR operator will have a laptop with the correst version of software (unless you are using Emerald and going to Dave Walkers RR, or something similar) Anything running windown 95 and above will be fine. Sorry but most of the software that is around for download for systems will not entertain anything that old. I am using 2000 for DTA but could really do with XP. It is unlikely that any laptop with Win95 on it will have a battery that still works and will need mains power all the time which is a right pain in the paddock and a replacement battery will write off the lap top in terms of cost. On 5th Sep, 2011 Vegard said:
9th Sep, 2006 at 11:03:39am
I think it depends on the ECU, DTA/Emerald/Omex probably need an upto date system, but MegaJolt/Squirt will run fine on an ancient 95 system.
9th Sep, 2006 at 02:42:27pm
On 09/09/2006 11:03:39 Tom Fenton said:
I know what you are saying regarding battery life but a cheap 12v-mains inverter sorts this problem out. Got one Maplins £30 - as had a shag nasty lappy (Compaq)with no battery - nothing but a pain died eventually. Bought a T22 s/h for £250 with two batteries which I keep/charging/ discharging. Much better for paddock use. In the workshop I have a PC and a long lead on the pot box. On 5th Sep, 2011 Vegard said:
208 Posts Member #: 438 Senior Member London |
10th Sep, 2006 at 08:57:19pm
I'm using a Pentium 2 based IBM Thinkpad.
11th Sep, 2006 at 12:05:45am
On 08/09/2006 16:11:09 colas said:
Anything will do from the last 5-6 years. Make sure it has a serial port. The USB adapters are a pain in the arse. The PCMCIA to serial cards work a treat though. 9.85 @ 145mph
