| Home > Wanted > Exhaust elbow | |||||||
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
19th Apr, 2004 at 10:33:28pm
i am currently collecting material to convert my midget with a turbo, i am in need of an exhaust elbow, a waste gate actuator and a heat shield.
20th Apr, 2004 at 10:22:25am
You should of said mate, reckon ive got 2 out of 3, ill have to look at exactly what ive got as im not 100%
20th Apr, 2004 at 12:42:39pm
I think I've got a 10psi actuator off a montego and a standard 4psi off a metro.
20th Apr, 2004 at 09:45:50pm
guys, if the heatshield is only a deflector and not a heatsink than dont bother, ill fabricate one
21st Apr, 2004 at 07:51:28am
I've had a quick look and I can't fine eithet actuator at the moment. If I come across them I 'll get back to you.
21st Apr, 2004 at 11:19:05am
a standard actuater will do 10 psi when a bleed valve is employed, you will have use a stronger spring in the "dumpvalve" in the plenum..a very very simple job.
