Home > General Chat > cooper S head!
JT
Member #: 637
Hertfordshire
hi
my dad said that his mate has an old head he thinks is off a old 1275 mini, he brings it round and it has the 2 extra holes and big valves in it.
looks like a cooper S head!
needs a bit of tidying and a referb etc
i also need to cheack that its not cracked, best/easy ways of doing this?
if i get it all in good working order, what sort of power increase should i gain on a standerd 1275 motor?
im thinking of building a cheap runaround mini so i dont need to rush the project once iv got all the parts for it!
cheers
josh
My build thread..
Dangerous
Member #: 417
My head has 2 extra holes(that I drilled) and big valves,but I wouldn't call it cooper s
You won't gain anything unless it's in pristine condition. The valve throats on the A+ heads are better than the old S heads as well.
Is it a 12G949 or an AEG163?
JT
Member #: 637
Hertfordshire
the only numbers on it are on top.
they are:
OWO
EG16
10
there the only numbers and letters on it.
what do you think it is?
cheers
josh
My build thread..
I'd say "EG16" is in fact AEG163 if you look more closely.
This is an old Cooper S head, they are prone to cracking between the valve seats so look at this first.
andeh
Member #: 97
Near Daventry, midlands
im guessing OWO is supposed to be MOWOG aswell...
JT
Member #: 637
Hertfordshire
there are holes either side of those letter & numbers
yer im going to cheack it over.
what is the best way, is there some sort of method?
would it be worth fixing it if it was fixable?
i could get the head welded up by a good friend for a few beers.
cheers
josh
My build thread..
Se7en
Member #: 446
Burntwood Staffordshire
If it is an old S head it will not have valve seat inserts for unleaded use.I would clean it up stick it on ebay and use the funds to go towards
better modifications.
Sound advice IMO. You are much better starting with a 12G940, flog the AEG163 to the period/concours/historic rally boys.
JT
Member #: 637
Hertfordshire
how much would i get for it would you think?
My build thread..
turbo hogster
Member #: 178
stowmaket suffolk
double check valve sizes as the early 1275gt's had the extra holes as well.
but if a true s head will be worth a few bob
