Home > Help Needed / General Tech Chat > fuel lines
crazykyle
Member #: 1247
las vegas nv usa
is it better to run the fuel lines through the bulk head and run them inside the car or run them under neath the car*indifferent**smiley*
turbo kyle
Dangerous
Member #: 417
Underneath is safer in event of a crash
turbochargedstu
Member #: 908
gateshead
unless you hit speed bumps and take off like ET. then inside is better
balls to the blower!!!
Richie
Member #: 628
i run inside on all my motorsport stuff and most of me road cars. if you crash a mini hard enough to rupture fuel lines i would rather they were ruptured away from hot exhausts. down to you. dangerous is right. but i will be fitting mine inside the car for this build too, up the center of the tunnel then through the bulkhead, so all lines are in the middle of the car and at the safest point for side impacts and front/rear :)
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
