Home > Help Needed / General Tech Chat > contactors
Arno
Member #: 233
Beugen, Netherlands
Can anyone tell me at what rpm the standard contactors are floating?
Do I need electronic ignition on an A-series Turbo?
Arno
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
as std they all had eleccy ignition...
Alex
AlexF
Arno
Member #: 233
Beugen, Netherlands
i am dutch and not really familar with off englisch, sorry, im a quick learner though i can say arse already.
i run my midget with 5500 rpm now with standard contactors, what rpm can I expect from a turbo, and from wich point do i need electronics?
Arno
I used to run contactors (or points) up to 7500rpm no problem.
Most turbo engines make maximum power at 6000rpm, so they should be fine.
Electronic ignition is still better though as it never fails in the wet like contactors.
Wil
Yeah id agree, points are fine.
Also with it being in a midget the issues of water and wet weather are vastly reduced.
Just get the advance curve altered to suit the engine.
