| Home > Help Needed / General Tech Chat > split rim bolt torque value?? | |||||||
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
25th Sep, 2006 at 01:41:30pm
i'm replacing all the bolts in my MB split rims for obvious reasons inherent with these MB wheels
25th Sep, 2006 at 02:35:01pm
Carl is your man to answer this one.....
1425 Posts Member #: 690 Post Whore Norfolk |
25th Sep, 2006 at 05:08:50pm
Dan - I wouldn't think you'd want to take any M6 nut and bolt combo this high - remember the nut you are using is made of platercine not high grade steel! - same goes if you are planning on putting washers under the heads of the bolts, these are plastercine as well, if you torqued to 17Nm the very small surface area of the bolt would bite into the low grade washer - causing yield then the bolt would come loose, not a good idea! - I would have thought 6-8Nm would be more than sufficient spread over 12/16 bolts..........
If Carling made Mini engines
25th Sep, 2006 at 06:54:52pm
my info came from image years ago, there recomedation was 10lbs,
25th Sep, 2006 at 07:15:26pm
look in FAQ , torqe settings..
26th Sep, 2006 at 06:51:24am
thanks for the info guys, must admit i'd had a re-think after i posted regarding the different materials of the bolt and the alloy rim/centre and the effects of expansion, although i'd not considered the nut/washer as a factor
Edited by dan on 26th Sep, 2006. |
26th Sep, 2006 at 08:43:07am
Another thing - the annoying part with cap heads is they are all 12.9 grade, which in itself makes the part fairly brittle - though strong, the worst part is the coating on these bolts - my advice (I'm a qualified/ time served chassis design engineer) is not to use 12.9 bolts with a zinc coating, a zinc based coating will cause hydrogen embrittlement on 12.9 grade material - look it up on google, the result of this embrittlement is fatigue failures early in the parts life through crack propogations along the surface. Always use fasteners which have a coating on them and that have been de-embrittled, quality fasteners will state this fact. If you can't get hold of these type of bolts and are stuck with zinc coated parts - lower the torque on them and keep an eye on them in stressed working conditions! For holding your wing mirrors on or something the zinc coated ones would probably be fine.
26th Sep, 2006 at 11:35:42am
i'm using the black coloured unbrako ones so should be okay on the zinc plating side of things
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
26th Sep, 2006 at 08:46:11pm
With the historic f1 cars we run a mb racing wheel, admittedly a little wider than the ones thast are used on minis. With a washer under the bolt head of a 12.9 grade M6 cap head bolt we torque them up to 9 lb ft and have no probs, but these wheels are only used for 8 weekends a year so fatigue cycles aren't really to be worried about!! |
17th Oct, 2006 at 08:08:12pm
But o/t but I have a set of oz splitrims on my golf.I need 2 new outer rims and the other 2 could do with a good polish around where all the bolts are.
