Home > Help Needed / General Tech Chat > 1098 turbo
mic
Member #: 1271
hi
has anyone done this? is the crank up for it? ive used the search function but cant find any info *frown*
cheers
www.retromods.co.uk
I think someone ios in the process of building one (is it clubbyturbo? I appologise as I should know).
I can't see a problem, you could eaisly build the engine to give max power around 6k so the limited rpm with the long stroke shouldn't be an issue.
mic
Member #: 1271
limited rpm?! i never driven any car over 6k! i assume it would pop if it went over 6ish
www.retromods.co.uk
benjamin
Member #: 621
nsw austalia
iv just finished mine its 1152 so 60+. was ran on the dyno last weekend and made 97hp on 6psi. we were limiting it to around 6500rpm just to be on the samfe side but there where no problems at all
click on my sig for build pics
Edited by benjamin on 25th Sep, 2006.
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
You need to start putting your foot down and hitting some revlimeters, it's grat fun. I suggest a test drive in a Honda S2000 which has a revlimit of over 9k.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I was never over 5k in the mini when it had the stage 1 998. Until I met that pesky kid in a Civic Sport that is...
On 7th Nov, 2008 Nic said:
naeJ
m
