| Home > General Chat > What drill size? | |||||||
26th Sep, 2006 at 05:42:40pm
Need to drill and tap a hole for 1/4 bsp and got a couple of questions.
26th Sep, 2006 at 06:01:20pm
26th Sep, 2006 at 06:05:42pm
great site, but.....no info on bsp or npt... "Turbo's make torque, and torque makes fun"
26th Sep, 2006 at 06:23:21pm
Size is 7/16" or 11.2mm from what I can remember, however if you are tapping into alloy castings (gearbox oil temp sender? or a pipe nipple into the inlet manifold?) it is worth using a slightly smaller drill to leave a shade more material to bite into. I have used 11.0mm with no problems at all.
26th Sep, 2006 at 06:24:53pm
11.8mm
26th Sep, 2006 at 06:28:12pm
cheers tom, must have posted while i was copy/pasting.
26th Sep, 2006 at 08:08:09pm
On 26/09/2006 17:42:40 joeybaby83 said:
2) If the union Im using has a 1/4 bsp thread, but is tapered do i need a specific tap, or will a parallel one be ok? I can't find my Zeus book either, but I seem to think that only the male part is tapered. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
26th Sep, 2006 at 08:33:00pm
You do need a special tap for a BSP taper in order to get the seal nice. I have used a normal bsp tap with a tapered fitting and with plenty of hydraulic thread lock and winding the fitting in well it has yet to leak!! The drilling size for 1/4 bsp is 11.8mm and the BSP taper is 11.2mm for the nominal sizes but depnding on the material alter accordingly.
