| Home > General Chat > New gearbox design | ||||||||||||||||||||||||||||
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
28th Sep, 2006 at 12:36:48pm
How much would you pay for a road going 5-6speed in sump gearbox for the a-series?
28th Sep, 2006 at 05:42:31pm
if you add...
28th Sep, 2006 at 06:14:44pm
need to also clarify if we're talking synchro box here - there is already a few 5-speed dog boxes aren't there?
397 Posts Member #: 694 Senior Member Shropshire |
28th Sep, 2006 at 06:58:38pm
I think the answer to the question is none of the above. Mainly due to the fact there are so many different a-series engines in different states of tune.
28th Sep, 2006 at 07:08:51pm
mmmm, I reckon somthing simmilar to swiftunes gearkit would be good where you can change/replace ratios ( multipeice laygear)
29th Sep, 2006 at 12:45:19am
Multipiece laygear sounds cool...
29th Sep, 2006 at 04:59:02pm
Unfortunately I had some problems with this poll, as the above mess clearly shows. Anyway, to elaborate a little further on my current progress plans and suchlike...
Edited by andeh on 29th Sep, 2006. I've seen the future and tbh its Pie
29th Sep, 2006 at 05:15:10pm
Aside from that 1 incident where I broke a tooth ( and of course cracked casings )
29th Sep, 2006 at 05:45:35pm
I'm not 100% sure I agree with you on the lack of decent transmission casings compared to blocks - 998's are still providing us with many casings - and even Mpi's - both of which have blocks of little / no use to the majority of us.
29th Sep, 2006 at 06:47:42pm
On 29/09/2006 17:45:35 TurboDave said:
Why not go the whole hog and switch it to a driven layshaft transmission whilst you're at it? That way you could do away with the idler gear train replacing it with two larger (correctly designed) helical gears instead? Got it in one the only concern i have is the weight on the two larger gears, but with better synchro's......
Another option is to use a current (OEM) transmission mainshaft assembly (gearing/synchros/bearings) 'as is' but modify it to fit in a new casing to suit the mini? From another very easy to get hold of (cheap) and relatively unwanted transmission (OE – I’m thinking ford (drawn up currently), but no reason why it can’t be from gm especially if theres a better synchro pack out there!) it should cope with the extra weight of the gears. On 29/09/2006 17:45:35 TurboDave said:
Then again - perhaps what peeps WOULD pay for is a properly engineered 4-spd synchro box - that instead of costing £260 - costs £1000. It would have fine-pitch helical CBN ground teeth; suitable bearings; A complete modern synchro pack - maybe something like a twin/triple cone unit pulled straight from a Corsa transmission for example? The plan is to produce a gear and shaft set as total cost is reasonable and allows for ratio changes. Then add components in from another box (synchro components). If I’m going to do this I may as well go the whole hog and stick another gear or two on, the gearbox also splits itself up into 3 compartments or two gears per compartment easily with current design as well. On 29/09/2006 17:45:35 TurboDave said:
I'm not poo-pooing - and will offer my experience of transmission design if you needed it; I just think that there isn't enough demand to warrant the effort to do something that is actually 'worth' doing (if that makes sense?) I take all criticism and suggestions on board and appreciate the time taken to reply!!! This isnt MF or TMF.
Your experience would be very, very, very welcome! At the moment the gearset is drawn up in brief (gears, shafts), but the case needs work and this is where im coming into cost problems as the cost of a new casing is almost as much as the rest of the components put together (excluding drop gears) This will happen, maybe not en-mass if nobody is interested, but I will do it for myself and will always extend the offer to make up a box for anyone else. I've seen the future and tbh its Pie
29th Sep, 2006 at 06:51:03pm
On 29/09/2006 17:15:10 stevieturbo said:
Aside from that 1 incident where I broke a tooth ( and of course cracked casings ) The Tran-X kit stood up very very well against my car, I drove it for some 50-60,000 miles when turbocharged, and a lot of them were quite abusive miles. There wasnt a day went by that didnt see me hit WOT several times. Perhaps lack of traction helped the box though ? I would hazzard an estimate that I was making around 180bhp or thereabouts, with what felt like quite a bit of torque too. I think I could safely say more torque than a n/a 16v A-series will ever produce. So if your intention is to build a box that will only handle 160bhp.... Is it really that much better than what is already available ?? The means for quoting 160bhp is thats my target for a reasonable road going 16v engine. No reason why it couldnt take more, expecially compared to the design of the original. Thats an impressive mileage compared to the output, did it get rebuilt within that distance? I've seen the future and tbh its Pie
29th Sep, 2006 at 07:55:54pm
How do the ratio's from the biniS / Diesel / ST170 transmission look? This is a pretty recent and very sweet shifting transmission from getrag - which given their pedigree must be a stong, reliable basis?
29th Sep, 2006 at 08:29:14pm
Rebuilt....for gearbox related problems, aside from the incident, I dont actually recall replacing any gearbox parts, but it has been a long time since I was driving it. But I think I remember ok.
