| Home > Wanted > Pipe (oil drain?) | |||||||
21st Apr, 2004 at 07:11:57pm
I need the L shaped pipe that goes from the bottom of the turbo the the block. Think its an oil drain, mines split! Anyone know waht they are called so i can price one up? Or just got an old one that is recyclable? Can i also ask, do they usally have jubillee clips on them to hold them on? Mine didnt and thats what leaked causing me to take the engine out thinking it was the diff!!! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
21st Apr, 2004 at 09:02:54pm
if your on about the blue silicon pipe avonbar do the original ones are expensive about 20 quid +vat id put jubilee clips on it if i was you ive got them on mine and if comes off it wont take long for it to pump all the oil out of your engine this experiment was carried out at the rollin road day no longer a series, but still 1.3 turbo.
21st Apr, 2004 at 09:41:21pm
Yep, good experiment too! About 30 seconds and 1litre of oil was lost!!!
22nd Apr, 2004 at 09:07:33pm
ok iain! Maybe a cheap oil feed/drain combo!
22nd Apr, 2004 at 10:13:09pm
Obviously be able to come to a deal as postage will be less.
Edited by iain on 22nd Apr, 2004. |
23rd Apr, 2004 at 06:00:40pm
ok if you have one, add it to the head steady, and email your address to james.fawcett@btinternet.com and ill send the cash. Mine doenst look too bad, so im wondering if it had just popped off rather than split, but id rather not use it! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
1st Apr, 2005 at 08:18:24am
Iain.. I really need one of those pipes as well. have you got any? On 13th Jul, 2012 Ben H said:
339 Posts Member #: 399 Senior Member Austria |
1st Apr, 2005 at 09:21:32am
are SAMCO/SPARCO pipes good enough? |
1st Apr, 2005 at 09:41:55am
i bought such a thing...
1st Apr, 2005 at 11:10:53am
they should be, i honestly havent got the cash to lay out for an order at the mo as im trying to get my engine built asap.
1st Apr, 2005 at 11:11:53am
Which diameter is that pipe? I haven't got the engine here with me you see :) On 13th Jul, 2012 Ben H said:
450 Posts Member #: 449 Senior Member Oxford |
1st Apr, 2005 at 11:37:16am
Try a company called SFS they do lined silicone and all that sort of piping loads cheaper than samco etc
Edited by mikemph on 1st Apr, 2005. |
1st Apr, 2005 at 02:27:41pm
3/4" ID vegard Edited by iain on 1st Apr, 2005. |
207 Posts Member #: 193 Senior Member Aylesbury |
1st Apr, 2005 at 06:18:02pm
There is one of these hoses that you need on eBay at the moment.
