| Home > Help Needed / General Tech Chat > Engine Advice | |||||||
82 Posts Member #: 1278 Advanced Member Bedfordshire |
1st Oct, 2006 at 07:03:20pm
i am currently in ther porcess of rebuilding a mini it is going to be a miglia replica with a turbo engine the shell is being done by a friend who races mini sevens but i need help with the engine after something i read on jimsters website. He did not seem to rate MED very highly and this worries me as i have brought a engine from them it is in kit form so luckily i can get someone to check it over the spec is
1st Oct, 2006 at 07:09:49pm
Spec sounds OK.
1st Oct, 2006 at 07:13:37pm
cheers i may take you up on this i wondered what else i could do to the engine to make as much power as possible, i want to run around 15/16 psi as when people seem to start running 20 or more they seem to be unreliable
1st Oct, 2006 at 07:15:55pm
As Tom suggests, use smallish valves. I'd use 31mm exhausts with the 35,6 inlets. If using 32s it'll be VERY fragile. On 13th Jul, 2012 Ben H said:
1st Oct, 2006 at 07:29:05pm
The main spec is good enough to make 200bhp.
1st Oct, 2006 at 08:54:47pm
You can't go far wrong with Tom building your engine for you. Team www.sheepspeed.com Racing
