Home > Help Needed / General Tech Chat > Fuel Lines
1380Turboman
Member #: 221
When running fuel lines internally (inside the car) must they be briaded? Does anybody know who sells braided hose this length in the correct diameter and how much it roughly costs
Carl
Member #: 95
liverpool-on-sea
to be honest id only use metal pipe weather runnin on the inside or outside. if you are set on braided pipe most good minisuppliers sell it but i think it is a bit expensive though
Im just going to use solid stainless tubing, not that expensive and much safer inside the car. Then braided at each end for the flexible bits.
Still not sure exactly where im going to run them yet.
spidfer
Member #: 84
How easy is it to work with metal fuel lines? - for a relative novice that is?
I use braided hos inside the car. To meet MSA regs you need it braided (probably for MOT too)
I got it from Demon Tweeks, around ?5 to ?15 per meter depending on pressure rating and internal diameter.
If you hunt around you'll probably find it a bit cheaper.
Wil
Surely pressure tested and approved tube is ok though? Basically stuff we use at work that is certified to 2000+psi.
Good stuff and free *wink*
Carl
Member #: 95
liverpool-on-sea
the stuff i used was from avonbar it is solid made from copper i think its very easy to bend into shape give was a bit on the expensive side theres some posts on here somewhere about pipes i thgink too
Jim
Member #: 125
Hmmm... I've just bought 3m of 8mm rubber fuel line from Avonbar. The guy there said that it was fine for the turbo conversion...?
Jim
Yep thats fine, i used it.
Just curious but how much was it?
I got 10ish metres of reinforced hoses for around ?10-15
That was 8mm ID.
icklebits
Member #: 228
im using copper microbore plumbing pipe, 8mm internal bore and cheap ?8 for 20metres lol!
ryan
Nick
Member #: 154
Midlands
yep, i used the same too! cant beat a bit of microbore, with some rubber for the connections and the awkward bends round the subframe/steering rack area
