Home > Help Needed / General Tech Chat > Recommended Coils
1380Turboman
Member #: 221
Whats the best coil to use in conjunction with a mk1 electronic dizzy?
Any info appreciated.
Paul.
For some reason it's just slipped my mind, i can't remember what it's called, but i know for electronic ing set ups, you need to use the right coil as there is a difference between that and a normal points one.
sauber 200
Member #: 245
best one if you can find one is a ducellar,i will find out any other
info numbers etc(has got red casing)
sauber 200
Member #: 245
hi again.
ducellar 520067A K5 unipart item
hope this helps.
1380Turboman
Member #: 221
Thanks mate for the info.
Much appreciated!
Paul.
1380Turboman
Member #: 221
Much appreciated!
Paul.
