Home > Help Needed / General Tech Chat > oil feed kits? which make?
jufferb
Member #: 775
stourport-on-severn, worcestershire
I know this topic has been covered time and time again as i searched and people have there own opinions on make. i want the braided pipe and the t-peice.Where do you get the big bolt from that goes throug the banjo and the t-peice from? also which is the best suplier to get the whole kit from.
cheers
If in Doubt, go flat out !!!
I think some people have bought kits from ebay recently that have had the wrong parts/threads.
Personally I would buy the kit from Avonbar as it will fit first time with no hassle.
yep, quality stuff from avonbar, good service too,
I bought a braided oil pressure line and some other stuff fom them, and was perplexed when just the oil line turned up, gave them a bell and was told they didn't have the oil line in stock so they got it shipped straight from the manufacturer, and the rest of the stuff should be there later that day, sure enough it turned up a couple of hours later.
You don't get that kind of service from Minispares!
yeah the avonbar type kit is the best. same supplier as i use and its made for the appilcation rather than a normal hydraulic hose.
I would normally say me but i dont have time to order any *happy*
its minipart that have been supplying the wrong threads on their banjo's.
he's been 'sorting it' for 8 weeks and still hasnt sent me the correct banjo...:(
ended up buying one from avonbar, and arrived the next day...and more to the point it fitted!!
metroturbo
Member #: 989
North Yorkshire
I pointed this out last year to minipart, after buying one on ebay.
Carl
Member #: 95
liverpool-on-sea
avonbar!!!
