| Home > Help Needed / General Tech Chat > Head Gasket and a Turbo removal | |||||||
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
9th Oct, 2006 at 09:17:36am
Just me again :(
9th Oct, 2006 at 10:45:35am
Payen BK 450 is the gasket to have, make sure the head surfaces are spotless and flat.
9th Oct, 2006 at 11:02:42am
if you wan the full turbo head gasket set with the proper manifold gasket get your motor factors to order you a payen DK451, thats the full head set and costs around £25.
9th Oct, 2006 at 11:16:45am
so is it DK 450 or 451 :)
9th Oct, 2006 at 11:42:17am
well just spoke to Avonbar they recommended the rover gasket so went for that and for a gasket for the manifold also at 1.95 something....bargin....
Edited by t@z on 9th Oct, 2006. |
9th Oct, 2006 at 12:19:29pm
BK450 is the part number for just the head gasket, DK451 is the code for the complete head set.
9th Oct, 2006 at 12:58:38pm
there is always some play in the shaft, if it doesnt smoke dont worry |
9th Oct, 2006 at 12:59:22pm
Play in the shaft, which direction? Axially or laterally? On 13th Jul, 2012 Ben H said:
9th Oct, 2006 at 01:38:25pm
i think the movement was side by side, and yes it did smoke on start up and when came on boost :( |
9th Oct, 2006 at 02:39:59pm
Axial or radial |
9th Oct, 2006 at 02:52:18pm
just on start up and boost not on idle (i think), all these long words, think i will get my dictionary out later and have a play with it |
9th Oct, 2006 at 03:07:32pm
while the heads off stick some guide seals on . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Oct, 2006 at 03:19:41pm
the head has bronze guides is this what you mean.
9th Oct, 2006 at 04:06:41pm
no taz .. on top of each guide there is a black rubber oil seal , to replace them you need to remove the spring with a spring compressor and pop a new one on the top of the guide , its a classic place for minis to leak oil into the chamber and so create smoke . of course if its a new head or not v old then the seals would presumably be new and not need changing. Edited by robert on 9th Oct, 2006. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Oct, 2006 at 04:28:14pm
i believe the head to be relatively new, i'll get my mate to have a look for me as he has more knowledge on this kinda stuff than me....trying to learn but its a slow process.
9th Oct, 2006 at 04:45:20pm
Just ring Avonbar again and save everyone else's time on the forum!
9th Oct, 2006 at 05:01:09pm
wel bit late now maybe do for tomorrow..
9th Oct, 2006 at 06:47:45pm
i dont find you annoying at all taz , we all started with no knowledge at some point in our lives Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
10th Oct, 2006 at 01:42:58am
On 9th of Oct at 11:42am t@z said:
well just spoke to Avonbar they recommended the rover gasket The Payen BK450 is identical to the Rover gasket.... In fact, Payen more than likely make them for Rover. Are proper turbo inlet/exhaust manifold gaskets still available ?? IS anyone using a steel shim head gasket yet ? 9.85 @ 145mph
