Home > Help Needed / General Tech Chat > dump valve?
fuiafonte
Member #: 695
PORTUGAL-VISEU
anybody here knows what type is this dump valve?
http://www.youtube.com/watch?v=XDVfqfYHZ2c
can i put them in my MG Metro Turbo?
thanks
hard to say without seeing it
any dumpvalve can be fitted to your Turbo metro
the vacume line is T in to the the servo line, and the dump valve is usuallly welded into plenum chamber
have a look on the forsale section i think giallofly AKA john flannigan is selling the plenums already converted to accept a dump valve
baily dump valves seems a good choice!
there are so many diffrent ones on the market out there now adays
blitz is another popular choice
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Now that we're on this subject, is there any types/brands that are not suitable because of fuel contanination? Mine came with the carb I bought off ebay but might change it at some point.
On 7th Nov, 2008 Nic said:
naeJ
m
I know some people found that the Bailey piston type dumpvalve sometimes stuck. This was apparentley due to fuel vapour swelling the seal. I'm sure there's a different type of seal available to solve this problem though.
Phil. *smiley*
Jay#2
Member #: 648
Yeah I know Avonbar supply special seals with their bailey ones that resist swelling but just wondering if any ebay purchase will do. I guess I'll find out!
naeJ
m
t@z
Member #: 452
Chester, UK
i just you an a-spec space ship thing bought from minispeed (i know i know) i do have another though nt sure on make....
www.twitter.com/lilpinkiy
Eh ??????
i had a bailey one, it was fine when it was upside down, but when i put it the right way up it seized open
ive tried avonbar twice and the new seals that everyone talks about arent available
so i tried bailey so i could get a new seal and sell it on, but they will only do a recon service for £30, and ill i want is one piddly seal
JT
Member #: 637
Hertfordshire
iv got a forge one thats going on mine and the bloke i bought it off said its very loud, but i only got it as it was cheap and i got my head and a few bits with it.
ill let you know what it sounds like once its all together......dont holf ur breath though itll be a while lol
My build thread..
a lad i know has a starlet, which sounds like that, hes got a hks dumpvalve on it
t@z
Member #: 452
Chester, UK
Eh ??????
when i manage to get over to my car where its kept i'll take a pic for you...
j_d_jag_mini
Member #: 979
Gated type dump valves are the best, most popular and most trusted on performance turbo cars here, I run one on my car, my particular one is made by DragR here in N.Z...is all polished alloy exept for interal gate and its twin trumpet...extremely loud !
There is one new type of design dump valve now on the market...will let ya know if i can remember what it called.
Jeremy
1975 MkIII Morris Mini 1300 Turbo, 100bhp...if only it could run long enough to drive it legally!
fuiafonte
Member #: 695
PORTUGAL-VISEU
and this tipe of dump valve do you know wath is the tipe?http://www.youtube.com/watch?v=uY2zj6W5TrM&mode=related&search=
t3gav
Member #: 229
Gavin@minispares.com
kent
Think the seals were made of viton (spelling?) and i'm sure i found a place on the web that supplied them in all kinds of sizes for a couple of quid, might be worth a shot.
Yea im pretty certain they would be Viton, if you can find some made out of Kalrez it would last longer, much more stable at high temperatures. *wink*
Ric
Member #: 36
Basingstoke
so, what's the general concensus on which is better; piston or diaphragm? I heard diaphragms rip, but it seems like pistons stick.
Ric
Member #: 36
Basingstoke
oh yeah, and just watched the clip of the m3 turbo. The sound you are hearing there isn't a dump valve, it's wastegate chatter.
The way to get that, is to block the overboost valve in the plenum, set the boost pressure on the actuator (think it needs to be over 10psi to get the noise properly) and go for a rag.
AlexBs car sounds pretty similar to that and he doesn't run a DV and is on about 12psi.
Wrong Ric I am afraid.
The fluttering noise you hear is in fact turbine stall, as you shut the throttle and the pressurised air then travels back to the point of lowest pressure, which is the air intake trunking from the air filter. To get there it has to travel past the turbine blades, even though the turbine is still windmilling from exhaust gas.
In summary, even though it sounds pretty cool, it is NOT GOOD!
Ric
Member #: 36
Basingstoke
Ahh, i knew that could happen, it didn't realise that was what it sounded like. The two sounds are quite similar then or am i getting confused.
