Home > Help Needed / General Tech Chat > AF 460 head gasket ?
AF 460 head gasket any one had any problems with this gasket on 73.5mm over bores ??
i have not, but....... just wondering ?
compared to the BK 450
I've used them in NA engines. Very good gasket!
andeh
Member #: 97
Near Daventry, midlands
In NA engines its all about having good head bolts/nuts and the right torque setting, i guess that goes for all engines though.
No experiance other than that, particularly with FI, sorry.
Turbo Shed
Member #: 30
Epsom, Surrey
AF460? i'm sure i use the AF470 on my turbo with no problems on 1293cc or 1380cc.
I think the AF 460 or whatever number it is, is identical to the BK450, exceept the BK 450 has additional copper rings around the front coolant passages.
AF460 - http://www.minispares.com/Product.aspx?pid=37368
BK450 - http://www.minispares.com/Product.aspx?pid=37447
Entirely different
I did consider the AF460 for the 1400 what with a bigger volume and what looked like a little larger fire ring???? though i've never seen it in person
There defo a couple of variations of gasket, back when I ran my car...
The factory Rover turbo one ended up identical to the BK 450
The early versions where the same, albeit a different colour ( light ) and didnt have sealing rings around the front water ways.
While on the subject of gaskets....
I was having a little search and found this.
http://www.ferriday.co.uk/copper/copper.html
They offer some sort of sealing ring system, and also say they do them for the A-series..
Anyone heard of them or used their system ??
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I think John Kimmins is using a ferriday gasket on his K1100 conversion. Correct me if I am wrong John:)
Yep, he does.
I posted that a while back when deciding gasket choice for the 1400.
You need a perfectly flat block and head, and then whether you also aid sealing of the water and oil passages with weld seal or not is up to you. Could always 'o' ring the passages.
Copper is deffo a good option, as you can get one offs made and its re useble.
Anyone know how much the feriday gaskets are?
Circa £80
Does the ferriday stuff require any machining ??
Just a picture of my last engine build. 1303cc 10,8:1 comp AF460 head gasket:
