| Home > Help Needed / General Tech Chat > Max boost with N/A rings? | |||||||
141 Posts Member #: 954 Advanced Member Fort Collins Colorado USA |
11th Oct, 2006 at 10:47:52pm
The shop that did my turbo install warned me against turning up the boost too much because naturally aspirated engines are generally set up with too small a ring gap for higher boost. They said they open the gap up on anything intended to run >9psi.
1275 with Back Door Turbo |
12th Oct, 2006 at 08:10:06am
New rings or old rings at present in the engine? I must say, I've torn down a turbo engine once imported from the UK which indeed had a ring gap "failure" Heavily scored. I never thought about it to be the heat from the turbo that did it, but maybe. Makes sense though.
12th Oct, 2006 at 02:11:39pm
Old rings. I'll do a compression test, but the engine has always run strong and doesn't smoke.
12th Oct, 2006 at 02:35:28pm
I will bet my life that on the Mini range og pistons rings are the same turbo or not. If JE or other big companies have got different rings I do not know. However, aleways gap yuur rings. If your rings are old, the gap will be bigger than when they were new. If you gapped your rings when you installed the pistons, it will be bigger now. Go ahead, have fun :) On 13th Jul, 2012 Ben H said:
1300 Posts Member #: 829 Post Whore essex |
12th Oct, 2006 at 11:28:56pm
Its up to the engine builder some times i run 14" on a ford x/flow for racing because of heat and engine revs 7000rpm 1293 Turbo mini
12th Oct, 2006 at 11:41:12pm
the intercooler will help some what
Edited by BENROSS on 12th Oct, 2006.
13th Oct, 2006 at 07:25:43am
I don't think an intercooler would help Ben, because we up the boost with that fitted :) That's the reason for fitting one isn't it :)
