| Home > Help Needed / General Tech Chat > New Turbo Found, ID Help Required! | |||||||
48 Posts Member #: 1244 Member Bagshot, Surrey |
14th Oct, 2006 at 06:19:58pm
Hi Guys,
14th Oct, 2006 at 07:02:23pm
I think it's a 55 or 60-trim compressor, with the 0.35 A/R turbine.
14th Oct, 2006 at 07:31:51pm
What should I do rebuild my T3 metro turbo as it starting to smoke or make a manifold & give this one a try? |
14th Oct, 2006 at 09:59:57pm
I'd put this one on Team www.sheepspeed.com Racing
14th Oct, 2006 at 11:13:51pm
What spec is your engine / are you planning on it being in the near future???
14th Oct, 2006 at 11:31:47pm
Engine is currently a standard 1275 Metro turbo lump, I haven't fully decided what engine spec I will go for when the rebuild starts but it's likely to be pratical for money reasons as I don't want to keep striping the thing down. Currently looking for a simple set up of say 1293cc, already got a stage 3 head but will add dump valve, uprated actuator & run it sensible around 8psi. Current turbo is shot and smokes so will need rebuilding but I have the new one mentioned but it's phyiscally a lot smaller & more compact than the Metro T3 turbo.
15th Oct, 2006 at 10:49:02am
On 14th of Oct, 2006 at 11:31pm Supereds said:
Hands on experience is no problem as i'm an apprentice served toolmaker by trade but now director of an engineering & fabrication company, I have access to any machine tools I require & can get someone to manufacture my parts for free:) what have you got to lose then. go for it. no longer a series, but still 1.3 turbo.
15th Oct, 2006 at 11:18:23am
graham ,
15th Oct, 2006 at 06:10:41pm
Thanks Robert, disregarding that the T2 turbo I have is new & I will need to rebuild the T3 Metro one i'm currently running which is better? What are the advantages & disadvantages of using either?
15th Oct, 2006 at 06:31:20pm
probably half the people on here use t3 and the other half use t2. its been disscussed do a search. but i think most the people that have changed to a t2 have not been dissapointed. no longer a series, but still 1.3 turbo.
15th Oct, 2006 at 10:03:52pm
going a bit off topic here, has anyone who had tried a T2 gone back to a T3? Team www.sheepspeed.com Racing
15th Oct, 2006 at 10:31:16pm
not me.....infact i havent even tried a t3 so im not one to talk |
16th Oct, 2006 at 10:04:08am
graham ,
16th Oct, 2006 at 12:18:48pm
Thanks again Robert, from what advice you've given I'm going to use the new T2 turbo i have & manufacture & new mainfold when I get time!
16th Oct, 2006 at 01:43:33pm
On 16th of Oct, 2006 at 12:18pm Supereds said:
Thanks again Robert, from what advice you've given I'm going to use the new T2 turbo i have & manufacture & new mainfold when I get time! Why not just mount it on the Metro Turbo manifold, as a few of us have done ? Job sorted !! Phil.
16th Oct, 2006 at 01:46:47pm
at least i think its jim that does them ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
16th Oct, 2006 at 06:02:50pm
I could manufacture the adaptor plate just to mount the T2 onto the Metro manifold but making the manifold complete it would look similar to Mirage one.
16th Oct, 2006 at 06:39:43pm
Why go to all the trouble of making a manifold, when the Metro one will do the job ?
16th Oct, 2006 at 06:57:05pm
I see your point but why do people buy Mirage manifolds if what they already have could be modified to do the job?
16th Oct, 2006 at 07:03:18pm
On 16th of Oct, 2006 at 06:57pm Supereds said:
I see your point but why do people buy Mirage manifolds if what they already have could be modified to do the job? All i need do is the drawings & I can get the mainfold fabricated where I work. no bulkhead cutting is needed with the mirage kit, dont know if the bulkhead needs to be cut when using the metty manifold and t2 tho. no longer a series, but still 1.3 turbo.
16th Oct, 2006 at 07:17:46pm
yes it does....
