| Home > Help Needed / General Tech Chat > spot welder | |||||||
14th Oct, 2006 at 06:51:10pm
im going to put new outer sills on me car (pukka ones) and want to do best job possible is it worth hiring or buying (second hand) electric spot welder for the seems . last times i did sills i used me mig and they wernt that neat a job. :) how easy are they to use.
14th Oct, 2006 at 07:10:11pm
VERY easy...
14th Oct, 2006 at 07:38:11pm
Carl I have a spot welder you can borrow, you'd have to come and fetch it though.
14th Oct, 2006 at 08:15:03pm
I "plug" welded new sills on the wifes 35 last year and the MOT guy failed it.
14th Oct, 2006 at 09:07:20pm
cheers tom i may take you up on that, but dont need it just yet.
On 14th of Oct, 2006 at 08:15pm Axel said:
I "plug" welded new sills on the wifes 35 last year and the MOT guy failed it. He stated that all weld repairs must be continuously welded! I was right pissed off. Best check that spot welding will be passed by your MOT guy. if you fit patches or oversills then they have to be seem welded, if you replace a panel so long as its fitted as it was in the factory then thats fine. iirc no longer a series, but still 1.3 turbo.
14th Oct, 2006 at 11:16:00pm
I basically wouldn't put new sills on and tell the tester they were new. Paint them, underseal them, and whatever. Tell him you stripped them back to bare-metal and re-painted them if needs be - but just don't tell him they are replacements.
96 Posts Member #: 251 Advanced Member Nottingham UK |
16th Oct, 2006 at 09:07:48am
I don't like spot welders, I thought they would be easier to do panels with so I bought an expensive computer controlled one. I personally found it hard to get a good weld with it and found plug welding much better. The result is a £400 spot welder sitting on my bench doing nothing!
