| Home > Technical Chat > An idea I had earlier. (Squish and short comp pistons) | |||||||
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
15th Oct, 2006 at 06:13:30pm
Ok, I have buggered about grinding my own heads and it wasn't really in the ballpark I wanted, I looked at decompression spacers, didn't like the idea of 2 head gaskets but reckoned it was a good idea to match the bores of the gasket to the piston bowls, thus retaining squish. So, I have a 1380 block and I'm looking to drop the compression ratio. Due to principles rather than finances now, I'd rather run cheap(er) pistons and spend the money elsewhere. The whole head gasket thing worries me and on a 73.5mm bore, I'd rather have some more meat. So, whilst I'm at it, why not go a weeny bit further and use Simca 1200 pistons with the short height? That's got to be a bad idea as a 74mm bore has to be worse. I like the idea of running more boost, hey, if you're thinking about it, you may as well try and get a bit more. So I was sat out on the doorstep and it came to me.
Bugger off, I'm getting there. |
15th Oct, 2006 at 06:27:52pm
How do you fit the pistons from the bottom of the bore,they won't fit that way crank bearing webs are in the way
15th Oct, 2006 at 06:29:13pm
Dangerous makes a valid point. On 17th Nov, 2014 Tom Fenton said:
15th Oct, 2006 at 07:04:37pm
Unless he inserts the "rings" after putting the pistons in.
15th Oct, 2006 at 09:13:01pm
Ahh, there's the snag. Fitting the rings afterwards would be difficult as the extra bored bit would have to be done mega accurately. I suppose they could be made to interference fit but I don't like that. The whole point was to save a load of money, perhaps do the job better.
16th Oct, 2006 at 08:07:00am
You could never have rings go through there with the proper ring gap. You'll have to have excessive gap to make it happen even if the pistons goes through. Also, you cannot fit the two center pistons from the bottom. On 13th Jul, 2012 Ben H said:
16th Oct, 2006 at 10:05:14am
Interesting idea to say the least. Not really worth a damn but an idea anyway. I don“t get it, why do you make things so difficult ? I am running 1380 with Omega 11 cc pistons pretty much flush with the deck. The head is close to 35 cc so I am running CR around 7,8:1. IIRC Stuart Gurr has cut heads close to 40 cc (success rate unknown...). I have successfully cut 2, and failed on one.
16th Oct, 2006 at 12:46:01pm
You're probably right, I would say that it would act like a big head chamber rather than a big piston dish. In the instance of combustion, I'd say that the pressure was exerted more in a downwards way on the piston more effectively than a dished piston. Not sure how much theoretical bollocks this would be, but if the surface area is less, you would have less heat rejection and perhaps a weeny bit more welly produced. I doubt a significant amount though.
Edited by Hedgemonkey on 16th Oct, 2006. Bugger off, I'm getting there. |
16th Oct, 2006 at 02:22:15pm
16th Oct, 2006 at 06:56:26pm
Not sure, but they're the sort of things you can pick up at an autojumble for f/a Bugger off, I'm getting there. |
16th Oct, 2006 at 06:56:31pm
