Home > Help Needed / General Tech Chat > Descompession plate?
Anton
Member #: 764
Staffordshire
I have a couple of questions regarding the 120thou decompression plates that are available?
1/ do they need a head gasket (or even 2?)?
2/ can they be skimed to create the correct compression ratio?
3/ are they a bodge, and shoiuld they be avoided?
4/ anything else to remember?
The reason i ask is i quite fancy Vmax's SC setup but i'm currently running 11:1 compression so obviosly need to lower this a little... pistons are already on the shoping list so that bits ok. I really dont wanna fork out for another head tbo
Edited by Anton on 16th Oct, 2006.
They are a bodge!
agreed with vegard and i would like to add that you will be forever repairing the gaskets
its NOT the way to go! *frown*
Edited by BENROSS on 16th Oct, 2006.
andeh
Member #: 97
Near Daventry, midlands
avoid it at all costs, the vmax kit, although very easy to fit, is pretty expensive aswell (i would get it myself, but its too much)
