| Home > Help Needed / General Tech Chat > Subframe Mountings | |||||||
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
16th Oct, 2006 at 12:48:56pm
I have a 1994 mini40 and am starting to modify it as funds permit, i already have a set of earty dry subframes and suspension bits powder coated red would it be possible to fit these in to my mini which has the late type bushes. Many thanks |
16th Oct, 2006 at 03:35:39pm
No. Swap the early subframes with a good friend, and solid mount the correct ones with brackets available from the Mini specialists. MUCH easier. This only applies to the front though. The rear "old" one will fit easily.
19 Posts Member #: 1293 Member Yorks |
16th Oct, 2006 at 04:59:50pm
I suppose you could mod the bulkhead cross member to take the 2 skinny bolts of a pre 76 subframe. I'd imagine an erly subframe in good knick would fetch a better price than a big bolt one so why not sell it 'n buy one that'll bolt straight on? I'd be inclined to keep the rubber mounts under the floor if your min's destined for the road - less noise 'n vibration. |
16th Oct, 2006 at 05:09:19pm
Thanks, got the powder coating done free, well actually a pint down the local so cant grumble, hope it wont look chavvy cant stand them, should look ok on a black mini, my mistake not that eary front subframe with two bolts just the large single will this still fit as it is from a 1970 clubman estate. |
16th Oct, 2006 at 05:21:50pm
1970 Clubman estate SHOULD have a twin bolt subframe.
![]() 455 Posts Member #: 953 Senior Member London |
16th Oct, 2006 at 06:05:02pm
. Edited by Bodge Job on 31st Mar, 2007. |
16th Oct, 2006 at 06:45:15pm
Of cause didnt mean 1970 meant 70's, reg of estate was ROL 239Y what ever age it is, it was given to me for free and was gonna use it to build a marcos but things changed, i worked out with the money a was going to spend on the marcos i can build a fully kitted mini which i wanted in the first place i had stripped and painted the parts to a good finish and am due to put them into my 1994 mini40 soon. Along with the estate i was lucky to get a mk 3 cooper s engine along with brakes, the engine is being stripped and rebuild to put in the mini 40 and using the A+ block which is in my mini now and turn it into a turbo motor when funds allow. |
16th Oct, 2006 at 06:54:13pm
On 16th of Oct, 2006 at 03:35pm Vegard said:
Also, red subframes is a bit Chavtastic ![]() lol hear that benross! lol
16th Oct, 2006 at 07:25:51pm
Y-reg?
