Home > Help Needed / General Tech Chat > MINI turbo. pumping out white smoke. dumped all its water
1959to2000
Member #: 257
i had a play with the boost on my mini van turbo. now it pumps out white smoke and has dumped all its water. it still starts and goes well. Is it the head gasket gone ? can u email me what u think. cheers
Pete
email Minis@dsl.pipex.com
thanks
Carl
Member #: 95
liverpool-on-sea
thats where id start dont forget to check your head and block arent warped *frown*
Yep i think head gakket too. check for any damage.
Payen bk450 is the best gasket to go for *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
mail sent!
AlexF
1976_mini
Member #: 259
grays, essex
yea sounds 2me like it cud b head gasget aswell.
it may b small but it purfectly formed
http://photobucket.com/albums/v340/1976_mi...roject%20turbo/
giallofly
Member #: 164
The Stig..
Newport Pagnell
That smoke is more than likely steam, often happens when the water side of the gasket fails..done that!
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Me too! The best part is not running it, but starting it up and getting surrounded in white smoke *happy* Its great setting off from petrol stations, i felt like a right muppet when it happened to me!
1959to2000
Member #: 257
head gasket was gone ! there is a tiny bit of piston slack. that ok ?
Pete
Should be ok. Only way is to see how it runs without stripping it and measuring it up.
If it runs ok then no worries, and dont play with the boost valve too much, you will make the engine go bang!!!
