Home > Technical Chat > Double Head Gaskets
What are peoples opinions about running with 2 Head Gaskets instead of one. I know some guys with Escorts who are doing it. Wondered if anyone had tried on a mini?
have a look at the gt17 thread on this section mikey .
Carl
Member #: 95
liverpool-on-sea
2 head gaskets= bad idea imho. if you wanna lower comp ratio have a word with benross about digging out your head chambers and do it properly!:)
Hedgemonkey
Member #: 360
Get someone with a milling machine to mill your chambers out circular. It works, failing that, get a decompression plate and use 2 gaskets, 2 gaskets next to each other are a bad idea. Snag is with plates, you need longer pushrods which is a new snag. How about getting a 1275E engine with factory low compression. If you're on a budget?
