Home > Help Needed / General Tech Chat > actuators v/s bleed valves, whats the difference?
icklebits
Member #: 228
heard and read a lot of talk about using a different actuator to increase the boos, and also using a bleed valve to do the same! whats the difference and which is best to use?? my current thiniking is to use a bleed valve for now to get it running and upgrade the actyator at a later date, anyone got any views on this?
ryan
Sounds like a good plan, bleed valves are supposed to increase lag and not be as accurate as a good acuator. Im going to do the same route on my next one.
icklebits
Member #: 228
good, i can spend money on actuators and stuff like that after, just need to get it running for now, gonna cost enough with rebuild bits, not to mention paying for the paintjob on friday lol
ryan
b12
Member #: 247
Kent/Surrey Borders
Actuators oh Actuators
Iain ever changed one with the ngine in situ ?
I have heard this is impossible
Someone also told me that you can play with the adjustable arm on the actuator ?
not quite sure what this will achieve ...
S
TurboLessTosser
Yeah i have, its not that bad, or atleast it wasnt on the one i did. Im pretty sure i took it all the way out. I just seperated the rod from the body and slide it out i think. Might of had to loosen the top engine steady to rock it forward.
Apparently the arm does alter it but it doesnt do it effeciently. They only really have one setting or something, its more to do with wastegate position.
These bits certainly add up!!
