Home > Help Needed / General Tech Chat > What shocks... Advice please
barkiboi
Member #: 591
Rugeley, Midlands, England
was thinking out uprating my suspension on my mini to adjuster rides and new shock was thinking the gaz lowered ride hight type or the avo which are best in your opinions.
Where is best to get them from any one to stay away from.
Will be running uprated cones not to fussed with comfort of ride as will be used for track days, also will be fitting 13x7s if this effects the choice.
Advice please.
Chris Barkas
ive tried spax, bilsteins and gaz, all of which id recommend but out of them the gaz are the lightest ones so...never tried avo
Stig
Member #: 694
Shropshire
avo definatly
Ben H
Member #: 184
Melton Mowbray, Pie Country
As with all things you get what you pay for. AVO, GAZ, Spax are al about the same price and all perform about as good as one and other. You will always find someone that has had problems with each though.
Out of those three I would go for the ones you like the look of most!!!!!
http://www.twin-turbo.co.uk
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I know these aren't on your list but konis aren't really adjustable in the proper sense of the word. For a start you have to pull them off the car for adjustment but they can only be adjusted to counter the affects of wear as opposed to alter performance. When I get bored of the konis I will go AVO I think.
On 7th Nov, 2008 Nic said:
naeJ
m
barkiboi
Member #: 591
Seen some AVO's they looked like coilovers without the springs they look very trad miglia inspired like the look of these not sure if they wll be a little bit too harsh for road use and not sure if they do one for the rear, what do you guys think About the damper described above are they a possibility.
thanks chris barkas
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
I like koni's for their ride and efficiency, some are adjustables on car but this have a cost.
spax were fine at tracks but really haven't the smooth of the koni's,
my friend mini is on avos and he really enjoy with them, I'm too,that was on track.
