Home > Help Needed / General Tech Chat > spark plugs
turboestate
Member #: 362
durham area
just a quik one what plugs should i be using with ford edis and ms also do you stick with ford plug leads help would be great :$
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
im using std mutro plugs, with a bigger gap
and fiesta leads
turboestate
Member #: 362
durham area
cheers nic are metro plugs resistor type ?
______
/___|_____
_ (@)___(@)
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
I have used volvo spark plugs from an 1.7 trubo engine (b18ft volvo 480 es 20 euro /set from vlovo) with good success (have to be used with dished pistons, but this shouldn't be a problem with turbo engines)
fab
yes, i think most are nowadays
though i would recommend getting the champion plugs as i too have not had much success with ngks in my car
turboestate
Member #: 362
durham area
yes with my experiance on bikes ngk,s arnt the best in the world as ive found myself getting them outa the box and them not even working once, LOL cheers for the replies this has straightend out the dilema.
______
/___|_____
_ (@)___(@)
Anyone used BP7ES plugs with any success?
BP7ES are OK for initial starting up the engine, this is what I am using them for, however I will be changing them after it is run in before it is rolling roaded.
I use BP7ES with no trouble at all. Well, not because of the plugs at least *wink*
MrTurbo
Member #: 814
Utrecht, The Netherlands
Did anyone try the NGK VX range? I'm now using the B8EVX plugs and they are fine. I will convert my Turbo to a MegaJolt system, so will have to change to the BR8EVX or BR7EVX plugs.
Does anayone know whether projected (BPRxxxx) or recessed (BRxxxx)electrode plugs are best for use in a Turbo? I my opinion a recessed electrode would be best, because there is no hot spot in the combustion chamber, but I could be completely wrong..
