Home > Help Needed / General Tech Chat > Just a quickie-Banjo bolt?
Is it advisable to use locktite on the bajo fitting on the turbo, not sure whether they tens to work loose at all?
Ive got some locktite 620 which is pretty good stuff?
Or
On the other end of the scale is it best to use some type of copper grease or neverseaze grease to aid dissassembly?
Cheers Matt
I've always put them on dry, never had a problem with them leaking, or removing them
and me, just pop it on
Nick
Member #: 154
Midlands
real men go in dry *tongue*
you've just lowered the tone so much, that you must be using specially modified hi-lo's
OK then im going in........dry.........Mrs *wink*
