| Home > Help Needed / General Tech Chat > Piston crown heights | |||||||
3rd Nov, 2006 at 02:29:18pm
Is the crown height on mega and omega pistons the same as standard turbo pistons. i.e do they go all the way flush to the deck like the turbo pistons?
Edited by Turbo Tel on 6th Nov, 2006. website:- http://www.terryhunt.co.uk
6th Nov, 2006 at 12:10:19pm
the omegs do
6th Nov, 2006 at 03:57:56pm
my megas are 35 thou down with 7cc dishes i get 14.5cc total deck volume.
6th Nov, 2006 at 09:31:23pm
Ok I guess I am finding that they are all different! What's confusing me is that convention says that "standard" pistons have around 5.2 cc of deck but my measurements and theory as well say that the turbo and regular Metro engines have pistons that go up to the deck.
6th Nov, 2006 at 09:39:28pm
11 cc dished omegas
7th Nov, 2006 at 07:51:27am
difficult to be very precise as it woud need to re mesure the used pistons which are sowhere it the worshop jungle.
10th Nov, 2006 at 02:00:21am
I contacted med and they said that Omega crown height is 1.499" I will call Avonbar tomorrow to get the height of the "standard" +40 but suspect your numbers are about right, for the 9.7 cc to work out at 9.4 CR the height must bee less than the 20831's which I also get going flush. I'll post the numbers when I get them.
10th Nov, 2006 at 05:36:43am
yes 10.5 cr mg mety not the 9.75 ones |
10th Nov, 2006 at 08:11:45am
the metty piston had about 6 or 7cc dishes the turbo has 11cc but i think the crown hight was the same but i could be wrong always looking for them bigger bunches of bannanas |
10th Nov, 2006 at 01:45:31pm
12th Dec, 2006 at 02:53:31am
I called around a bit and got the following:
Edited by Turbo Tel on 31st Jul, 2008. website:- http://www.terryhunt.co.uk
12th Dec, 2006 at 08:31:15am
mega 73.5 are 0.7mm down 20831 piston
12th Dec, 2006 at 11:50:27am
I got 10thou from the deck with my std turbo pistons so recon on 1cc deck volume
Edited by Sprocket on 12th Dec, 2006. On 26th Oct, 2004 TurboDave16v said:
17th Sep, 2008 at 08:02:12pm
Omega = 1.499" 38.07mm = 4.1cc (40thou)
18th Sep, 2008 at 12:06:58am
I would have thought that most aftermarket pistons will use the shorter deck hight to enable several engine configurations, allowing shaving of the block to what hight you want. On 26th Oct, 2004 TurboDave16v said:
18th Sep, 2008 at 11:37:32pm
On 17th Sep, 2008 Turbo Phil said:
Omega = 1.499" 38.07mm = 4.1cc (40thou) So if i'm reading this right, there's a 10cc dish in the cast Omega pistons & then 4.1cc in the crown to deck height, yes ? Thats what I was told but double check it.. As Sprocket says it seems that most aftermarket pistons are the so called "standard" height giving 4.1cc deck, the only ones that were taller seem to be the turbo and High CR metro pistons. Terry website:- http://www.terryhunt.co.uk
21st Jun, 2010 at 04:57:14pm
Thanks to Gavin at minispares I have been informed that their 73mm evo pistons sit approx 10thou down the block on a standard deck height. If something is worth doing, it's worth doing half of. |
2nd Dec, 2010 at 06:05:31pm
Omega = 1.499" 38.07mm = 4.1cc (40thou) So if i'm reading this right, there's a 10cc dish in the cast Omega pistons & then 4.1cc in the crown to deck height, yes ? Can anybody confirm or deny this? John's been talking to Vince at Avonbar today. Accrolites are now a minimum of £125 + vat per piston
Now looking at a set of plus 0.020 10cc Omegas. With the 4.1cc deck volume (I know that's on +0.040), 28cc in the head and a standard deck heigh, I get about 8:1 which is my rough target. On 11th Feb, 2015 robert said:
2nd Dec, 2010 at 08:02:18pm
acralites are a crown hight of 38mm, same as my old stock 1275 cooper S power max pistons.
2nd Dec, 2010 at 08:23:56pm
Thanks for the info and the offer. I'm still at the parts hoarding bit of the engine build. I'm thinking it's pistons for my little crimbo treat.
2nd Dec, 2010 at 08:45:14pm
On my forged Omegas (18cc) I need to remove 0,75mm to get the pistons flush with the deck. On 13th Jul, 2012 Ben H said:
2nd Dec, 2010 at 10:43:34pm
On 2nd Dec, 2010 apbellamy said:
Now looking at a set of plus 0.020 10cc Omegas. cast?, from memory mine sit 0.8mm down the bore with an un-skimmed deck and that was 0.5mm further down than the std spi pistons that came out, i still have the pistons to hand if someone could tell me how to measure it edit or rather work it out without building the engine up lol Edited by Brett on 2nd Dec, 2010. Yes i moved to the darkside |
3rd Dec, 2010 at 07:40:34am
yes, cast.
3rd Dec, 2010 at 11:32:01am
On 3rd Dec, 2010 apbellamy said:
yes, cast. by my maths 0.8mm deck height at +0.020 ((2x pie )x 7.112) x 0.08) gives 3.575cc (approx) so is within my tolerance. Anmdy 0.1 mm is basically 0.004" so 0.8mm is 32 though |
3rd Dec, 2010 at 11:49:17am
Cheers Carl
