Home > General Chat > Brace bar under subframes between suspesion areas. thought?
vrooom
Member #: 138
I worked under there today, fixing oil leak. and this thought occured to me,
why not i fit the brace bar from front subframe to other side, it would stop flexing, under hard cornering, it would improve handling.
Or is it so strong it doesnt need one?
Only prob is brace bar would sit low beacuse of diff cover,gearbox linkages.
what is your thinking on this?
I personally don't think you would find a noticable difference, as the subframe is fairly stiff already.
Although seam welding the subframe is probably beneficial if you are thinking on that track?
Bodge Job
Member #: 953
London
Edited by Bodge Job on 31st Mar, 2007.
IMO it is not "NEEDED" on any car, but it is one of those little easy to do modifications that all add up to the greater goal when a car is finished.
Bodge Job
Member #: 953
London
Dangerous
Member #: 417
Dan Ludlow has a brace bar accross the back of his metro where the hydrogas units are(approx same place as the rear donuts on a mini)
still got beat by Mr Flan
So, how much does it flex?
yeah, i don't where you mean from and to.
vrooom
Member #: 138
Sure it flex enough, looking at the design, conisdering we use sticky tyres etc.
Heres an idea then, try something different to the norm and let us know the results??
isnt the cross member just a massive fuckoff strut brace?
paul25
Member #: 596
Once you have cut the bulkhead to let in the turbo box you have lost most of the stiffness from the body, but the stiffness between the towers of the subframe is pretty good so I don't think a brace will make much difference.
