| Home > Technical Chat > Minispares new layshaft | |||||||
12th Nov, 2006 at 08:46:14pm
It's a while since we touched on this subject.
12th Nov, 2006 at 08:49:43pm
I'll try to remember to take a file with me next time i go to minispares. LOL On 28th Aug, 2011 Kean said:
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
12th Nov, 2006 at 09:04:28pm
http://www.key-to-steel.com/Articles/Art117.htm
Bugger off, I'm getting there. |
13th Nov, 2006 at 08:54:42am
On 12th of Nov, 2006 at 08:49pm mini13 said:
I'll try to remember to take a file with me next time i go to minispares. LOL Remember that hte file-test that was executed previously mentioned on this site was worthless. The shafts are only hardened on the bearing journals, not in the middle. On 13th Jul, 2012 Ben H said:
13th Nov, 2006 at 04:11:36pm
On 13th of Nov, 2006 at 08:54am Vegard said:
Remember that hte file-test that was executed previously mentioned on this site was worthless. The shafts are only hardened on the bearing journals, not in the middle. ??? Where was that noted ???? On 17th Nov, 2014 Tom Fenton said:
13th Nov, 2006 at 05:15:03pm
selective hardening, that must be an interesting process and rather expensive as well! Bugger off, I'm getting there. |
13th Nov, 2006 at 11:55:33pm
Yeah i didnt even know there was a conclusion either lol. |
14th Nov, 2006 at 07:21:20am
i done the test with miniwilliams
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
14th Nov, 2006 at 07:08:31pm
shocked to say the least by that :o
14th Nov, 2006 at 07:14:11pm
Well, I've bought one of these new ones. Should be with me tomorrow.
14th Nov, 2006 at 08:41:30pm
On 14th of Nov, 2006 at 07:08pm andeh said:
shocked to say the least by that :o Question: how would you harden only a couple of areas of a component in a production enviroment? There is a process called induction hardening. Basically the area to be hardended is inserted into an induction coil. The coil then effectively heats just the area in the coil effectively heat treating that area only. There are variations for tempering / softening which is often used on threads on hardened items (obviously hard threads can break up). It all depends on the correct type of material being used of course. In some applications flame hardening can be used although most of the steels that I know which can be flame harden aren't going to be great for be layshafts. There are also some selective hardening processes which use an electrically based plasma too catalyse the process. I am sure that a transmission specialist (TurboDave) could shed a lot more light on the materials used in transmissions. Every day is a school day ...........
14th Nov, 2006 at 09:02:48pm
Im getting a new T56 built, and having the gears cryo treated, which is supposed to increase strength.
Edited by stevieturbo on 14th Nov, 2006. 9.85 @ 145mph
14th Nov, 2006 at 09:07:44pm
mmm i read some where its possible to get a whole built up engine cryo'd! On 28th Aug, 2011 Kean said:
14th Nov, 2006 at 09:33:03pm
didnt they do that in back to the future? "Turbo's make torque, and torque makes fun"
15th Nov, 2006 at 12:25:03am
Nah, your thinking of Superman with his Kryptonite treatment On 26th Oct, 2004 TurboDave16v said:
15th Nov, 2006 at 03:18:32pm
Picture of new Minispares "performance" Layshaft.
15th Nov, 2006 at 08:22:40pm
i think one of the big killers is some of the after market ones has holes which are slightly smaller than the standard ones.
19th Nov, 2006 at 06:04:38pm
Look at a brand new ring gear on a flywheel. Only the teeth are hardened, also the same on a handbrake ratchet and the throw out stop (on the bearing end, the thread is still soft).
shocked to say the least by that :o Question: how would you harden only a couple of areas of a component in a production enviroment? I seriously doubt it! |
